If you need any info - Page 5 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #61
Old 06-24-2013, 08:22 PM
Tatum81 Tatum81 is offline
Tatum81 is starting off with a positive reputation.
I have 5 lugs, seem to be about an 8 inch pattern.
  #62
Old 06-24-2013, 11:20 PM
DragonPen999 DragonPen999 is offline
DragonPen999 is starting off with a positive reputation.
Nevermind, I'm an idiot that just made a $1000 mistake. Oh well least I can scrap it for a few bucks.
  #63
Old 06-25-2013, 02:09 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
You missed a set by a year:
http://www.ford-trucks.com/forums/11...8-pattern.html
Dodge motor homes had that pattern--5 on 8". They are 19.5 tubeless, which ends up with a little shorter tire than you probably have.
9R x 22.5s will work, but finding 5 on 8" 22.5 wheels is probably impossible.
5 on 8" split ring wheels with tube tires would be better than the Firestone wheels.
You mention "Budd" wheels. Budd is a wheel maker, and afaik, did not make the "widow maker" type wheel. HOWEVER, the widow maker Firestone wheels are the "Budd" type wheel, vs. the "Dayton" type wheel which is very different. Scroll down here for a brief explanation and pic:
what are budd wheels? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Do your rims have a split locking ring around the outside of the front wheel and the insides of the duals? Or is there a separation inside the wheel?
Ford two piece rims
Look at the video in post #4 here. My dad had a GMC 6x6 with these wheels, and he had the big ax-looking hammer to unseat the bead. What fun to change tires on that POS. (at least he bought a 1" impact for the lugs--finally)
Looking for the specific difference between "Split Rings" and "Split Rims/Widowmaker"
  #64
Old 06-25-2013, 02:36 AM
Thanks for the thread references. My wheels don't have a split ring around the outer, they are a two piece rim that separate in the middle. Do you know any more about which years the dodge motor homes had my bolt pattern? Just so I can narrow my search. I appreciate all the info being shared.
  #65
Old 06-25-2013, 02:52 AM
I'm thinking 1970s....
RESOURCES
  #66
Old 06-25-2013, 03:03 AM
Thanks, I am using every angle I can to track down a set of "safe" wheels. I am really hoping to stick with something near the same size and not have to change the axles.
  #67
Old 06-25-2013, 09:24 PM
If anyone is looking, there are two sets of 22.5 F600 rims on e bay right now... 6 lug, not 5. Maybe they are right for somebody.
  #68
Old 06-28-2013, 01:33 PM
Asparky112 Asparky112 is offline
Asparky112 is starting off with a positive reputation.
Hi I posted in another thread for a VIN decode but then saw this here so thought I maybe should post it here... 74 Ford F700 Gas dump 5/2 running gear from the ad so here is the Vin>>> VIN# F70EVU48354... Just wanting to know how easy engine parts are to get... Thus the reason for the decode..
Thanks
RON
  #69
Old 07-03-2013, 07:27 AM
72rustwarrior 72rustwarrior is offline
72rustwarrior is starting off with a positive reputation.
HI NUmberDummy,
Can you tell me how the consecutive numbers are organized for the production runs and DSO options. MY Econoline has a VIN ending in "Q02422" Which looks to be the last of 1972's production it also has a special order DSO number of "1277" after the District code. (which I believe is the 1277th vehicle with Special Order Parts) Do those numbers refer to only the Econolines? the model within the Econolines? Or the whole production line in 1972? Any insight into how these codes were derived would be great. Can you look-up a model using the DSO code to find what it shipped with originally?
Thanks
  #70
Old 07-09-2013, 02:29 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Serial number (last 6 digits of VIN) apply to all series of 1948 and later trucks, 1961 and later Econolines, 1966 and later Bronco's.
6 digit DSO: First 2 decode to specific Ford District Sales Office that the dealer ordered the vehicle from.
Last 6 is the Domestic Special Order number. 1277 is related to your Econoline, but 1276 and 1278 could be any truck, Bronco, Econoline or a Passenger Car.
1972 serial number range: M40,001-Q00,000 / 1973 serial number range: Q00,001-S60,000.
Beginning 1970: Production date printed on the upper left corner of the Safety Standard Certification Label, glued to the B pillar below striker plate.
I have no way to get info for a Domestic Special Order, but you can get the info for a fee from martiauto.com
Late 1980's: FoMoCo was planning to THROW AWAY all the 1967/79 records. Kevin Marti, a Mustang/Shelby 'nut' in Phoenix AZ found out...and got ALL OF IT!
  #71
Old 07-09-2013, 08:26 AM
Thanks, I knew you would know this answer. I was wondering about the Marti report and if it was any good...
  #72
Old 07-09-2013, 08:45 AM
But I did see a Ford Shop-Tips somewhere that said Q20,000 was the start of 1973 for the econolines (page 10 Vol 11 #2) but on Page #9 the BRONCO 1973 started with Q00000.
  #73
Old 07-09-2013, 09:31 AM
Quote:
"I never saw a purple cow, I never hope to see one. But I can tell you, anyhow, I'd rather see than be one." -Gelett Burgess, famous San Francisco raconteur. Burgess was born...in Beantown.
Left/Right upper: 1972 / Left/Right lower: 1973.
  #74
Old 07-09-2013, 10:14 AM
Did the DSO affect the date? (like make production run later because of the special order?)
  #75
Old 07-09-2013, 10:15 AM
Also Mine was made (as I understand all Econolines were) made in Lorain, did the date code change per location of plant?
Oreogn FTE Member, Broken Axle Shaft in Seattle 892504x4 Washington Chapter 0 12-31-2016 02:11 AM
VIN there, done that (decoder needed...) Ste-Van Large Truck 17 03-02-2016 12:31 PM
Need a Diesel performance repair shop...Seattle Dan V 1999 - 2003 7.3L Power Stroke Diesel 5 10-27-2015 07:28 PM
Any place to Hot Tank parts in Greater Seattle Area? Sir.Dino 1957 - 1960 F100 & Larger F-Series Trucks 10 02-27-2015 10:39 AM
What do I need to take the muffler off? Brody Olson 1999 - 2003 7.3L Power Stroke Diesel 7 04-04-2014 08:55 AM
Tags
accessfreightliner, cards, cpd, dealer, ford, heavy, login, parts, sterling, syracuse, truck, tsl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
