OLD DECODES
#557
Well I think I got it ran down thru another source, it's called a :
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly | eBay
I don't know if I should proud or ashamed that I stumped you but I'm leaning towards shame because I was using bad description.
Thank you for the help.
#558
E8HZ-2310-A .. Bracket Kit-Brake Camshaft-Right Rear / Obsolete
1988/89 F700/900 with Bendix 16 1/2" x 7" air brakes.
Last MSRP: $660.85 - Dealer net cost: $429.55 / The ebay price is a roaring bargain, but the parts catalog description is a bracket kit, but I only see the bracket.
But, if the truck does not have this type of air brakes, this is the wrong part number.
#561
C = 370 2V or 429 4V
C = Oakville Ontario Canada Truck Assembly Plant.
EJ8815 = 1979.
146" Wheelbase.
COLOR: Blank*
F600 2WD (gas), 19,700 lbs. GVWR
GA8: GA = Black Heavy Duty Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
65J:
65 = Rockwell Single Speed Rear Axle / 6.83-1 / 15,000 lbs. Rear Axle Capacity.
J = Ford 5,000 lbs. Capacity Front Axle with P/S or Ford 4,700 lbs. Capacity Front Axle with M/S
19,700 lbs. Gross Vehicle Weight Rating.
150454:
15 = Newark NJ Ford District Sales Office, where the original selling dealer ordered the truck from.
0454 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
*When there is no COLOR code, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
#562
#563
Seller listed the part number:
#565
Vin/Info Tag decode 1985 F700 Dump
Posted this in the top of the forum but will cross post it here in hopes that NumbersDummy will see it and decode it for me.
Picture of Vin/Info tag are attached.
I've decoded the vin using other tools and it comes up as an LN7000 which is flat wrong so I'm coming here to get it decoded correctly and confirm which A/T type/model is in it and what axle ratio it has.
1985 F700, 8.2L GM/Allison w/ A/T (Allison but which model)?
Thank you in advance.
#567
N850
Hello Bill, im working on a 1969 N850 , I'm looking for the driveshaft carrier bearing, I found a part no.
D4HZ-4800-A, could you check to see if this is the right number and if this part is available anywhere.
Thanks, Bill
Thanks, Bill
#568
If you aren't sure, post the TRANS code stamped on the Warranty Plate, riveted to the left door face below the latch.
