OLD DECODES
#482
C = 330 2V Medium Duty FT engine.
R = San Jose CA Assembly Plant.
K62870 = 1971.
174" Wheelbase.
M = Wimbledon White.
F610 = F600 2WD (gas) .. 21,000 lbs. GVWR
4B8: 4B = Black Vinyl (Heavy Duty) / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F3C: F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity // C = Ford 6,000 lbs. Capacity Front Axle.
21,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3800 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
#483
im trying to repair the hacked wiring on my 64 n600 and i cant find a fuse block of any kind ? does my truck have one ? i also believe my stock headlight switch has also been replaced , there are no fuses on it either ? any help is appreciated
#484
There aren't very many fuses lol. Should be right by the lightswitch in fact, just under the dash. At least it is on the 100 series. Headlight switches don't use fuses, rather a kind of integral thermal circuit breaker.
#486
Help With Parts Identification
Hello! could you please identify the three parts I have marked in the attached photo and a brief detail of how they are interrelated? Thank you!
1976 F250
F25JRC50290 5 W 71
F250 4 38J G A
Dads76xltAttachment 157136
What are Parts# 1, 2, & 3?<br/>
1976 F250
F25JRC50290 5 W 71
F250 4 38J G A
#488
oil filter
could you help me out with oil filter cartridge part number and if available a spin on filter adapter oil looks well past due!
Vin# F70DVJ22921
F70 = F700 Gas
D = 330 2V Heavy Duty FT engine
V = Kentucky Truck Assembly Plant
J22921 = 1970
this is the info you decoded for me but my cab sticker says 361 in power train what's your input?
Vin# F70DVJ22921
F70 = F700 Gas
J22921 = 1970
#489
1966/78: E is the VIN engine code for the 361 FT engine.
Compare the VIN on the Warranty Plate to the VIN on the registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
There is no Spin-On Oil Filter adapter kit available for 330 2V H/D; 361 or 391 FT engines.
The above used C1TZ-6731-B ..Cartridge Oil Filter (Motorcraft FL-20).
#490
yeah I think the door has been swapped so I'm going by the cab sticker it's the only tag I can read but still can't see a vin on it I don't know if any of the numbers that I can see on that sticker have any I.D. relivance? thanks for the help got a bed with pump pulled out we've had sitting around for years we hooked it up to the pto and up up and away it went! try to get some reinforcements in there and put it in before winter
#491
Decode VIN and need fuel tank sending unit
Hi there. I recently purchased a 1967 N600 and have started to fix it up. VIN is N60DUA43764. Need at fuel tank sending unit to start. And was thinking about adding in another tank if I could find one.
Thanks for all your help in this forum. Greg
#492
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
A43764 = 1967, assembled November 1966.
The original fuel tank contained 18 gallons, was located inside the cab.
What's wrong with the sending unit, not reading correctly?
The fuel sending unit float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
The float is still available from Ford, but Carpenter sells a brass/plastic float for about 5 bucks.
The complete sending unit is obsolete, there are 5 still available NOS
#493
Thanks for the information. This truck has a frame mounted tank to the rear of the drivers step. It does not look like it ever had a cab fuel tank. It seems like it holds about 16 gallons. Any idea where a sending unit for it might be available?
#495
I just purchased a 1992 E 150 conversion van for its wheelchair lift system. but it came with no manuels or information on the conversion. so I need all the information I can get. I thank you in advance for your help, what a great service.
