If you need any info - Page 2 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 03-05-2013, 11:13 AM
madrid london's Avatar
madrid london madrid london is offline
madrid london is starting off with a positive reputation.
replacement engine
Hi Bill, i have not been able to sell my truck and the band would really like to have use of it again so have decided to replace the engine. i have busted push rods for sure and may have too much damage to rebuild this one. so my question is where can i get a replacement? my VIN: C70EVS15579, also what other engine would be appropriate, and could i go with an automatic transmission without changing rearend. thank You.
Old 03-07-2013, 01:18 PM
suicidejockey77 suicidejockey77 is offline
suicidejockey77 is starting off with a positive reputation.
Bill, I have an 83 F700, 370 five speed, two speed rear. The hydromax monitor module failed. The part number is E1th-2co12-aa. I found a similar item on ebay, part number E0HZ-2C012-A. Will they interchange?
Old 03-09-2013, 10:13 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by suicidejockey77 View Post
Bill, I have an 83 F700, 370 five speed, two speed rear. The hydromax monitor module failed. The ID number is E1TH-2C012-AA.
Marked with ID engineering number: E1TH-2C012-AA = original Ford part number: EOHZ-2C012-A replaced by: E8HZ-2C012-A .. Monitor Assy / Available from Ford
MSRP: $173.63 / FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $ Discount price not listed, it should be about $114.60.
Old 03-09-2013, 11:09 AM
Thanks Bill, I makes me feel better that Im not taking a shot in the dark with that!
Old 03-09-2013, 10:32 PM
Quote:
E = 361 2V or 4V / 11 western states authorized FoMoCo rebuilder GPD (Genuine Parts Distributors - Tumador Engine) located in City of Industry CA
Give them a call (800-669-6012), ask if they still have FT engines available.
Old 03-10-2013, 12:07 PM
Genuine Parts Dist.
thank You Bill. i'll give them a call monday, or the mechanic will.
Old 03-17-2013, 08:11 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
Ok Bill,,, here is the new addition to the fleet
F60362231
The drivers door was swapped out with one from an F100,,, to bad, cuz the pass. door has the customcab surround.
Thanks Bill!
p.s. in re. to driveshaft,,,was able to get the coupler shaft straightened, problem solved!
Old 03-20-2013, 08:32 PM
Damion Anderson's Avatar
Damion Anderson Damion Anderson is offline
Damion Anderson is starting off with a positive reputation.
1956 Ford COE C600
Hello, Here is my vin-C60Z6H25626 (here is a link to the decoded vin--- http://www.vinwiz.com/1953-1960fordt...in=C60Z6H25626)
I am looking for a U-bolt strap kit for the rear transaxle. The guys I bought the truck off of disconnected the driveshaft and threw them away. I also need a gas pedal, and the connection from the carb to the oil bath air cleaner. Thank you very much!
Old 03-25-2013, 04:42 AM
kingston250 kingston250 is offline
kingston250 is starting off with a positive reputation.
oh thanks for this offer. You are really very talented and one of the best member to providing the info about the all type of parts.I should contact with you whenever i have any problem about the parts and their codes.
Old 03-25-2013, 04:51 AM
Quote:
Originally Posted by Pickupmanx2 View Post
Ok Bill, here is the new addition to the fleet: F60362231
VIN contains 11 digits, it's missing the engine (4th digit) and assembly plant (5th digit) codes.
F60 = F600.
Engine?
Assembly Plant?
362231 = 1963, assembled December 1962.
Old 03-26-2013, 09:19 PM
Quote:
F60 = F600.
Engine?
Assembly Plant?
Rut-ro,,, better go find it on the truck, that is what is on the pink,,,
Old 04-04-2013, 05:48 PM
El_Roacho El_Roacho is offline
El_Roacho is starting off with a positive reputation.
Mid 1990 big truck parts
Bill,
New guy here (lurked for a long time) .... I have a 1995 F800 rollback. 5.9 Cummins, auto trans. You appear to be a main source of info, so ............
I cannot find any Ford parts folks that will even begin to look up even simple components - I am sure, because of the age. I know there must be some availability - not tool long ago I redid a 64 C1000 with the help of a Ford parts guy here in town. Managed to locate all kinds of stuff - rubber, filters, etc. He is gone, no joy with anybody even attempting to locate parts.
After pretty simple stuff for the F800 - original rubber floor mat, break pedal rubber pad, fuse block - simple stuff.
Any suggestions as to what dealer/parts guy will take the few extra minutes to at least try?
My vin: 1FDNF82C2SVA82440
Thanks for any ideas as to who I might try.
Billy C.
  #28
Old 04-13-2013, 07:35 PM
69f10069 69f10069 is offline
69f10069 is starting off with a positive reputation.
NumberDummy,
This one might throw you through a loop. I just bought what I know is a 1969 F-100. The VIN on the door is incorrect but the title also has that VIN. Its Production numbers would put it as a '67 f100 but the title states the '67 VIN and then states it as a 1969 (I will have to figure out what went wrong there). The frame VIN on the other hand... this is where it is a little confusing so I am just going to give you the frame VIN. I do believe this one to be correct, but the production number would put it in a void between '68 numbers and '69 numbers.
F10YKD83640
Good luck! Hope you can figure it out for me.
  #29
Old 04-13-2013, 09:47 PM
Quote:
Originally Posted by 69f10069 View Post
NumberDummy,
F10YKD83640
F10 = F100 2WD
Y = 360 2V
K = Kansas City MO Assembly Plant.
D83640 = 1969.
1969 Serial Number Range: D82,001-G90,000.
1968 Serial Number Range: C00,001-D82,000.
1967 Serial Number Range: A00,001-B82,000.
  #30
Old 04-14-2013, 06:36 PM
hzl6cm's Avatar
hzl6cm hzl6cm is offline
hzl6cm is starting off with a positive reputation.
This one should be fairly simple, the truck is a '72 F-600 dump truck: F60CVP21549 <!-- / message -->
<!-- controls -->
VIN there, done that (decoder needed...) Ste-Van Large Truck 21 02-21-2017 04:19 PM
Oreogn FTE Member, Broken Axle Shaft in Seattle 892504x4 Washington Chapter 0 12-31-2016 02:11 AM
Need a Diesel performance repair shop...Seattle Dan V 1999 - 2003 7.3L Power Stroke Diesel 5 10-27-2015 07:28 PM
Any place to Hot Tank parts in Greater Seattle Area? Sir.Dino 1957 - 1960 F100 & Larger F-Series Trucks 10 02-27-2015 10:39 AM
What do I need to take the muffler off? Brody Olson 1999 - 2003 7.3L Power Stroke Diesel 7 04-04-2014 08:55 AM
Tags
accessfreightliner, cards, cpd, dealer, ford, heavy, login, parts, sterling, syracuse, truck, tsl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
