OLD DECODES
#228
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Retired Air Force working on restoring a 1963 f100 -- installing a new GM wire harness and hooking up my wiper switch to the wiper motor. I have a 2 speed wiper motor and switch C3TB-17A553-E. I was able to get the wipers to work, but unable to figure out the combo to allow the wipers to park. I must be missing a connection. The switch has 4 prongs. Can you help me out?
#229
Aerostar parts
Received a copy of your post regarding parts. I have a 1996 Aerostar, have owned 6 of them,. I am in need of the headlight adjusting screws. Part numbers are F29Z13032B and f29Z1303A. Most immediate need is for the one ending in B.
Thanks
Steve
Thanks
Steve
#231
Hi Bill,
#233
N70 = LN700 (gas).
H = 6.1L (370 2V or 4V). I couldn't find this code initially, as I was unknowingly looking in the wrong parts catalog.
V = Kentucky Truck Assembly Plant.
Now I know why I couldn't find the H engine code in the 1973/79 truck catalog:
GD6773 = 1980.
GD6773 = 1980.
#234
FT pulley interchange
I am helping my friend put power steering on his 1967 F750 with a 361 2V under the hood.
We managed to find an F600 with a 361 under the hood and P/S but it is was missing a few parts.
From surfing this site and looking at pictures on the internet, it looks like I need a pulley for the steering pump that bolts to the harmonic balancer. Anyone got any ideas on what other motors I can steal pulleys off of for a 361?
Am I missing any other brackets on this pump? There is a small bracket bolted to the pump you cannot see in this picture.
Anyone got a picture of their pump setup?
Thank you again for the help.
#235
1964/74 F750 361/391 / 1970/74 LN600/750 361/391
1964/72 C/F600 330 2V Heavy Duty / 1973/74 C/F600 361/391.
No Ford dealer or obsolete parts vendor has any.
#236
What does this mean? It was cast with one number and its part number was changed to something else?
Oh well, I was hoping something off of a FE truck motor would also work. I see more of them than FT engines.
#237
C4TZ-6A312-B double sheave outer crank pulley marked with engineering number C4TZ-6B359-B
All harmonic balancers and their associated outer pulleys are marked with engineering numbers, so they can be easily identified.
These engineering numbers cross over to the actual part numbers in Ford parts catalogs.
Left: Pic from text section of 1964/72 truck parts catalog listing the C4TZ-6A312-B part number, the C4TE-6B359-B engineering number and its specs.
Right: Pic from text section of 1973/79 600/900 (heavy) truck catalog lists the part and engineering numbers, but not the specs.
#238
Need youre help again Mr.Bill
Hi
I need a kickdown rod for my 79 f100 custom, 302, c-4. Connects link on steering column to link on trans (just to clarify).
Mines had about an inch and a half added to it, in length. gear change indicator is off to the left and no adjustment left to move it. I could cut and reweld but I would be happier (more confident) with a un modified part.
You found me the link for the trans end a year ago or so.
Time to pester ya again.
Thanks Art
Thanks Art
#240
Help me please. I want to know the year of this truck.
[QUOTE=NumberDummy;10538054]I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes.
My vin is. F25ACF90563
Text me or email me what you come up with please.
