If you need any info - Page 16 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #226
Old 08-26-2014, 07:09 PM
sendv4 sendv4 is offline
sendv4 is starting off with a positive reputation.
Could you decode my VIN# for me: VIN# F61ECH51646
Also I need a gas tank, a radiator, and a heater core for this truck. Thanks, Luke
  #227
Old 08-26-2014, 07:31 PM
Fabman54 Fabman54 is offline
Fabman54 is gaining momentum as a positive member of FTE.
Info needed
  #228
Old 10-16-2014, 10:24 AM
Golfusaf Golfusaf is offline
Golfusaf is starting off with a positive reputation.
Quote:
Originally Posted by NumberDummy View Post
I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes from the Rating/Warranty Plates and the Certification Label first used in 1981.
If you need parts, obsolete or not, I can look up the numbers, then search for them on two online websites to see if anyone has them. Then will post the part numbers, sources that have them.
If the parts are still available, I will list the MSRP and the FTE member discount price offered by sponsor PARTSGUYED.COM (Ed Olson, parts manager of Horizon Ford in Seattle WA).
I've been doing this jazz on FTE since 11/04/2006. And, btw: One of the parts locator sites is only accessible to FoMoCo Dealers.
Hi Bill,
Retired Air Force working on restoring a 1963 f100 -- installing a new GM wire harness and hooking up my wiper switch to the wiper motor. I have a 2 speed wiper motor and switch C3TB-17A553-E. I was able to get the wipers to work, but unable to figure out the combo to allow the wipers to park. I must be missing a connection. The switch has 4 prongs. Can you help me out?
  #229
Old 10-16-2014, 10:33 AM
Steve Aerostar's Avatar
Steve Aerostar Steve Aerostar is offline
Steve Aerostar is starting off with a positive reputation.
Aerostar parts
Received a copy of your post regarding parts. I have a 1996 Aerostar, have owned 6 of them,. I am in need of the headlight adjusting screws. Part numbers are F29Z13032B and f29Z1303A. Most immediate need is for the one ending in B.
Thanks
Steve
  #230
Old 10-16-2014, 03:14 PM
WB4TTO WB4TTO is offline
WB4TTO is starting off with a positive reputation.
Smile VIN Decode on ?79? F700
Have a 79 F700 dump bed with VIN N70HVGD6773
Any and All info would be much appreciated
Thanks, Richard Henry
  #231
Old 10-17-2014, 05:54 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Golfusaf View Post
Hi Bill,
Please type this question in the 1961/66 forum, this forum is for Large Trucks (500 and larger series).
  #232
Old 10-17-2014, 05:55 AM
Quote:
Originally Posted by Steve Aerostar View Post
I have a 1996 Aerostar, have owned 6 of them. I am in need of the headlight adjusting screws. Part numbers are F29Z13032B and f29Z1303A. Most immediate need is for the one ending in B.
Please type this question in the Aerostar forum, this is the LARGE TRUCK forum.
  #233
Old 10-17-2014, 06:04 AM
Quote:
N70 = LN700 (gas).
H = 6.1L (370 2V or 4V). I couldn't find this code initially, as I was unknowingly looking in the wrong parts catalog.
V = Kentucky Truck Assembly Plant.
Now I know why I couldn't find the H engine code in the 1973/79 truck catalog:
GD6773 = 1980.
  #234
Old 10-21-2014, 11:28 AM
Tobias Tobias is offline
Tobias is starting off with a positive reputation.
FT pulley interchange
I am helping my friend put power steering on his 1967 F750 with a 361 2V under the hood.
We managed to find an F600 with a 361 under the hood and P/S but it is was missing a few parts.
From surfing this site and looking at pictures on the internet, it looks like I need a pulley for the steering pump that bolts to the harmonic balancer. Anyone got any ideas on what other motors I can steal pulleys off of for a 361?
Am I missing any other brackets on this pump? There is a small bracket bolted to the pump you cannot see in this picture.
Anyone got a picture of their pump setup?
Thank you again for the help.
  #235
Old 10-23-2014, 06:48 AM
C4TZ-6A312-B .. Double Sheave Outer Crankshaft Pulley / Marked: C4TE-6B359-B / Pulley diameters: 6 59/64" & 5 53/64" x 3 5/32" long / Obsolete
1964/74 F750 361/391 / 1970/74 LN600/750 361/391
1964/72 C/F600 330 2V Heavy Duty / 1973/74 C/F600 361/391.
No Ford dealer or obsolete parts vendor has any.
  #236
Old 10-23-2014, 05:56 PM
What does this mean? It was cast with one number and its part number was changed to something else?
Oh well, I was hoping something off of a FE truck motor would also work. I see more of them than FT engines.
  #237
Old 10-24-2014, 03:13 PM
Quote:
C4TZ-6A312-B double sheave outer crank pulley marked with engineering number C4TZ-6B359-B
It wasn't 'cast' .. the pulley is stamped steel.
All harmonic balancers and their associated outer pulleys are marked with engineering numbers, so they can be easily identified.
These engineering numbers cross over to the actual part numbers in Ford parts catalogs.
Left: Pic from text section of 1964/72 truck parts catalog listing the C4TZ-6A312-B part number, the C4TE-6B359-B engineering number and its specs.
Right: Pic from text section of 1973/79 600/900 (heavy) truck catalog lists the part and engineering numbers, but not the specs.
  #238
Old 11-06-2014, 04:52 PM
fiveofsevin fiveofsevin is offline
fiveofsevin is starting off with a positive reputation.
Need youre help again Mr.Bill
Hi
I need a kickdown rod for my 79 f100 custom, 302, c-4. Connects link on steering column to link on trans (just to clarify).
Mines had about an inch and a half added to it, in length. gear change indicator is off to the left and no adjustment left to move it. I could cut and reweld but I would be happier (more confident) with a un modified part.
You found me the link for the trans end a year ago or so.
Time to pester ya again.
Thanks Art
  #239
Old 11-07-2014, 04:05 PM
Quote:
D8TZ-7A187-F .. Kickdown Rod / Obsolete
302/C4: 1978 F100/150 from serial number BE0,001 / 1979 F100/150.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
  #240
Old 01-06-2015, 06:24 AM
johnperrigin johnperrigin is offline
johnperrigin is starting off with a positive reputation.
Help me please. I want to know the year of this truck.
[QUOTE=NumberDummy;10538054]I have every Ford Truck Parts Catalog from 1928 thru 2001, so I can decode all the VIN info, codes.
My vin is. F25ACF90563
Text me or email me what you come up with please.
VIN there, done that (decoder needed...) Ste-Van Large Truck 21 02-21-2017 03:19 PM
Need a Diesel performance repair shop...Seattle Dan V 1999 - 2003 7.3L Power Stroke Diesel 5 10-27-2015 06:28 PM
Old bread truck seattle smitty 1967 - 1972 F-100 & Larger F-Series Trucks 25 09-10-2012 04:12 PM
He's Back.... FTE Jason Site Announcements 15 04-02-2008 11:10 AM
Discount Ford Parts Parts Guy Wyatt Vendor Specials, Discounts, Product Announcements & Group Buys 93 11-01-2007 01:34 PM
Tags
accessfreightliner, cards, cpd, dealer, ford, heavy, login, parts, sterling, syracuse, truck, tsl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
