If you need any info - Page 15 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #211
Old 08-12-2014, 07:23 PM
samjones12 samjones12 is offline
samjones12 is starting off with a positive reputation.
I have a 1997 Ford F150 XLT Extended Cab. It has the 6.5 ft bed. I need the OEM part number for the Left side bed cap with the Stake Holes. I have the Right Side Part Number (XL3Z-99291A40-<wbr>BAA ) I need the Left one. Thanks so much for your help!
  #212
Old 08-12-2014, 07:25 PM
I also need the part number for the 1997 Ford F150 XLT (6.5 ft bed) Tailgate cap. Thanks
  #213
Old 08-12-2014, 07:34 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
XL3Z-99291A41-BAA (replaced F65Z-99291A41-BAA) .. Moulding-Body Side Outer Upper-Left with 6.5' bed / Available from Ford
MSRP: $114.50 / FTE Ford dealer parts dept sponsor: silverstatefordparts.com online price: $79.01 (Gaudin Ford ~ Las Vegas NV).
  #214
Old 08-12-2014, 07:49 PM
Thanks
Quote:
Originally Posted by NumberDummy View Post
Welcome to FTE
I found the left side online just like you mentioned. Thanks So Much!
If I may ask, can I please have the part number for the tailgate cap as well?
Thanks again!
Sam
  #215
Old 08-12-2014, 09:14 PM
Found it!
Thanks again!
Sam
I found the part number for the Tailgate Cap. (XL3Z9940602AAA ) They had it in stock as well.
Thanks So Much for All Your Help!
Sam
  #216
Old 08-14-2014, 09:43 PM
edbenesch edbenesch is offline
edbenesch is starting off with a positive reputation.
F600 vin decode F60L7K14988
Hello - Hope I'm posting this in the correct area.
I have a fire truck, F600 with a vin F60L7K14988
Can you break this down for me? - Thanks Ed
  #217
Old 08-14-2014, 10:03 PM
Quote:
I have a fire truck, F600 VIN: F60L7K14988
Welcome to FTE
F60 = F600 (gas).
L = 534 4V
7 = No such assembly plant code, has to be a letter.
K14988 = 1971.
  #218
Old 08-19-2014, 04:45 PM
coalnation's Avatar
coalnation coalnation is offline
coalnation is starting off with a positive reputation.
I have a 1983 Ford C-8000 with the Alison a/t. My temperature sensor sender went bad and I need to replace it. Do you have any idea what ford part number this would be?
  #219
Old 08-20-2014, 11:35 AM
Hobby welder's Avatar
Hobby welder Hobby welder is offline
Private First Class, E-3
Hobby welder is gaining momentum as a positive member of FTE.
quick question, I found what appears to be a COE/big-job, 1956. But I am not sure, any specifics that I should look for? I have pictures, if someone could post them for me, rather than photobucket.
  #220
Old 08-20-2014, 05:54 PM
Quote:
COE (Cab Over Engine) aka Cab Forward.
  #221
Old 08-20-2014, 05:56 PM
Quote:
Water temperature sending unit? What size is the engine?
  #222
Old 08-20-2014, 08:57 PM
coalnation's Avatar
I guess I should have said transmission temp sending sensor. Here is a picture. Cat 3208 non turbo engine. I believe it's the Alison MT653 automatic transmission.
It has "AIRPAX 8315" and "300 14-65" printed on it.
  #223
Old 08-21-2014, 12:37 PM
I need additional info: The 8th digit of the VIN and the TRANS code printed on the Certification Label.
Here's the pic. The switch is basic part number 10B921 (shown at lower right) .. but there are two different types.
  #224
Old 08-25-2014, 04:29 PM
FilmCarp FilmCarp is offline
FilmCarp is starting off with a positive reputation.
Hi. I have an 84 F250 I am trying to put back on the road. The VIN is : 2FTEF26F3ECA99201. I tried contacting Ford and they tell me that this is not a valid VIN. It is on all the documents and appears to match the dash plate, but that has a bunch of junk on it that I can't get to yet, so it may be that the 0 is actually a 6. Any help or info is greatly appreciated. I admit that I have already gotten a bunch of good advice here. Thanks
  #225
Old 08-25-2014, 08:19 PM
Quote:
Originally Posted by FilmCarp View Post
Hi. I have an 84 F250 I am trying to put back on the road. VIN: 2FTEF26F3ECA99201.
Uh huh... It is valid, the IDIOT you spoke with at FoMoCo doesn't have a clue!
2FT = Ford Motor Company of Canada Limited, Ford Truck .. Complete Vehicle.
E = Class E, Hydraulic Brakes, 6,701-7,000 lbs. Gross Vehicle Weight Rating.
F26 = F250 4WD Pickup.
F = 5.0L 2V (302) V8 engine.
3 = Check Digit, FoMoCo usage only.
E = 1984.
C = Oakville Ontario Canada Truck Assembly Plant.
A99201 = 1984 Numerical Sequence of Assembly, the trucks specific serial number.
Just because it was assembled in Canada...doesn't mean it was sold new there. Look on the Certification Label for the DSO code, post what it is.
DSO will decode to the Ford District Sales Office in the city/state (or providence) the truck was ordered from. DSO examples: 13 = NYC, 16 = Philly, 17 = WA D.C.
VIN there, done that (decoder needed...) Ste-Van Large Truck 17 03-02-2016 12:31 PM
Any place to Hot Tank parts in Greater Seattle Area? Sir.Dino 1957 - 1960 F100 & Larger F-Series Trucks 10 02-27-2015 10:39 AM
95 Remote Ignition Modules rainbowATF 1987 - 1996 F150 & Larger F-Series Trucks 2 08-25-2009 06:50 AM
He's Back.... FTE Jason Site Announcements 15 04-02-2008 12:10 PM
Discount Ford Parts Parts Guy Wyatt Vendor Specials, Discounts, Product Announcements & Group Buys 93 11-01-2007 02:34 PM
Tags
accessfreightliner, cards, cpd, dealer, ford, heavy, login, parts, sterling, syracuse, truck, tsl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
