Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 06-26-2011, 12:08 AM
rangermark3tp rangermark3tp is offline
1992 Ford Ranger
rangermark3tp is starting off with a positive reputation.
Cool transmission instal
I have a 92 Ranger 4.0 with 5 speed manual transmission. Does the exhaust have to be removed to remove and install the transmission? If not, any tricks to getting it in properly?
  #2 (permalink)
Old 06-26-2011, 10:54 AM
Hank85713 Hank85713 is offline
Garage is empty, add now
Hank85713 is starting off with a positive reputation.
yes it needs to be removed. the Y pipe is in the way. Pretty much follow the directions in any manual. You will need to also remove the trans crossmember and then support the engine. A long 24 inch extension and univeral wobbly sockets will be needed. I also had 2 long bolts made up that fit in the holes so I can slide the trans in/out by myself. that way you dont need 4 hands.
  #3 (permalink)
Old 06-26-2011, 01:46 PM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all19704X4F250 is a name known to all
Good luck getting those 4 rusty bolts out of the exhaust manifolds to drop that Y-pipe. They will need some heat to get that done or unbolt the manifolds from the heads and let em hang. You should have enough clearance then.
__________________
Dan
Ignorance makes you start over!
IF IT IS MADE IN CHINA, YOU DON'T NEED IT!
Torque it down till it breaks off, then back it off 1/4 turn.
  #4 (permalink)
Old 06-26-2011, 06:32 PM
Roger1960 Roger1960 is offline
Roger1960 is starting off with a positive reputation.
Quote:
I just pulled an automatic trans out of an explorer without removing the pipe but it is a royal pain to do so. When I installed it into my Aerostar, I pulled the Y pipe and it was much easier.
Get some penetrating oil and soak the bolts overnight, then give them a shot with the torch followed with some more penetrating oil. If they are going to come out without breaking, then that is the best technique.
You might want to unplug the O2 sensor from the harness and just leave it in the Y pipe.
If you don't have a tranny jack, Harbor Freight has a cheap one that works pretty good, but you will need some wood to shim it as the tilt feature is almost worthless.
Good luck.
You should report back with your progress on this job, what went good what went bad and how you overcame the issues you found.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
