Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- How to Replace Serpentine Belt
Step by step instructions for do-it-yourself repairs
How to replace a serpentine belt
Here is a photo that shows the routing of the belt for dual alts.
Look for this:
Accessory Drive— 7.3L Diesel Engine Single Generator
<TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler Pulley (Without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
Accessory Drive —7.3L Diesel Engine Dual Generator
<TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>4 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
https://www.ford-trucks.com/forums/5...ml#post5243515
Stewart
Stewart
Look for this:
Stewart
Stewart
on
Stewart,
The small diagram you posted shows the tensioner relief going down, or "clockwise". That doesn't seem right, even for a dual setup.
It also shows what appears to be an A/C compressor clutch below the tensioner. That would be for a gasser, not a diesel, wouldn't it?
I'd lift up on the breaker bar to relieve belt tension if the actual belt routing looks like the full diagrams given.
Pop
Pop
I just did this a few weeks ago. No lock on mine(or I didn't find it) Just follow the sticker under the hood. It's not bad with two people, but is nearly impossible alone. You have to keep moving from top to bottom of the truck and I kept knocking one section off putting the next on. Opening the new belt a few hours ahead of time and let all the kinks work out before hand makes it much easier.
Stewart,
Pop
Pop
Stewart
