A/c compressor clutch - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-25-2011, 12:44 PM
Ridenred333 Ridenred333 is offline
Ridenred333 is starting off with a positive reputation.
Ok a/c wasnt working took it to a mechanic told me the the compressor was missing a clutch he recommended i put a new compressor. Is it possible just to put a new clutch in it and if so do i have to remove the compressor to put the clutch on it. Once again thanks.
Old 06-28-2011, 08:38 PM
anyone have any ideas on this
Quote:
Old 06-28-2011, 09:25 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
How the compressor can be missing the clutch and the belt is still on?
I guess front bolt come off and the clutch is not engaging the compressor? The clutches used to be sold as separate item, but times are changing and now dealers want to sell you whole assembly when you need a washer, or seal only.
Did you try to call a dealer or other part place?
Old 06-29-2011, 04:56 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
You can buy just the clutch. I wouldn't do it. The clutch often wears out because the compressor is failing and takes more torque to turn it. A new clutch won't last long, either. The best way to fix this is to replace the clutch and compressor.
Old 06-29-2011, 07:22 AM
thanks for both replies. ya they do sell the clutch by itself but as mark stated I wounder how long it would last.. The clutch is around $80 doing the whole system if i pay someone is about $600 meaing clutch compressor orfice tube and evap seperator thing plus labor.
Old 06-29-2011, 04:58 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
I replaced the clutch and pulley on my old 97 at around 160K. Sold it to my nephew at 200k and the compressor is still going strong.
YMMV, but for my money, replacing the external wear items made a lot of sense (and dollars).
Old 06-29-2011, 10:57 PM
Monster-4's Avatar
Monster-4 Monster-4 is online now
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
By not working what do you mean? Is it just blowing warm air? Is the clutch engaging properly? If not have you checked the gap between the clutch and pulley surface? You can get a shim kit from a Ford dealer and reduce the gap so the clutch can engage properly.
Old 06-30-2011, 01:33 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
A quick check is to measure the clutch air gap. If it's too wide, the magnetic coil can't get the clutch plate to engage dependably.
So many people were having a problem with this that I did a write-up so that it wouldn't have to be explained over and over.
Take a few minutes and try what you read here:
Compressor Clutch Air Gap
Let us know how it goes.
Pop
Old 06-30-2011, 07:14 AM
Sorry all i should have said what truck i have also. I have the f250 with the v10. I will check it out spring pop..Ya if blows but is warm air and i dont hear the compressor engaging at all. I will take a look tomorrow or this weekend.
Old 06-30-2011, 08:27 AM
The V-10's compressors are at the bottom, not the top of the motor, but the idea is the same.
Things are pretty tight and cramped around that compressor, so to get some room to work, you may want to test things, determine how much you need to adjust, then remove the de-gas bottle (coolant recovery tank) to actually remove the clutch plate.
It's not as easy as a diesel 7.3, but the repair is the same.
Pop
Old 06-30-2011, 01:40 PM
tcjhkbjt tcjhkbjt is offline
tcjhkbjt is starting off with a positive reputation.
I have an 04 F250 that I am having problems with my A/C as well. I was reading up on the clutch issue, but when I went to look at mine I did not see a bolt in the center of the clutch. Is there suposed to be one on that year model?
Old 06-30-2011, 03:57 PM
Yes there is! Got one FAST and install it!
In the meantime, pull your clutch plate off completely. You won't have A/C, but you won't have a metal disk fly off into the degas bottle or fan/radiator! Be sure to save the shim(s) that are there, too, for replacement/modification.
Here's what that bolt looks like:
http://springerpop.net/F350/images/compressor7.jpg
Pop
Old 07-01-2011, 07:06 AM
so do you think that would solve my a/c issue? I guess it would draw the clutch closer to the compressor right so that it would inguage? Thanks for your help
Old 07-01-2011, 07:15 AM
I noticed in the pictures that this compressor is on top of the motor behind the raditor cap. On my 04 F250 is it on the bottom of the motor?
Old 07-01-2011, 01:29 PM
That just means you don't have a 7.3, but either a gasser or a 6.0.
You still have an FS-10 compressor.
The physics of the whole thing remain the same. Your room to work may differ.
Have you heeded my note about urgency of getting a bolt in there? DO NOT drive your truck without a bolt in place!!!
Pop
2007 Expedition A/C Clutch not engaging Netroamer 2007 - 2014 Expedition & Navigator 0 06-28-2016 09:44 PM
locked up a/c compressor not letting motor turn over memphis_made 1997 - 2003 F150 6 11-19-2015 03:38 PM
1997 E-350 A/C compressor R T 1968-2013 Full Size Vans 3 07-30-2015 10:45 AM
A/C Compressor greatbatchw 6.0L Power Stroke Diesel 4 07-21-2015 02:40 AM
A/C Compressor stephenfaustin 1987 - 1996 F150 & Larger F-Series Trucks 2 06-04-2013 04:50 PM
Tags
60, ac, clutch, coil, compressor, compressorf250, duty, electrical, engage, f350, ford, make, plate, shim, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
