42-47 Bed Box vs. Later
I'm trying to decide whether to redo my bed box (bottom rot) or get another. Can't find middle x-members for '47 but lots for '48-50. Are they dimensionally the same. I've seen lots of 40-47's with '50 beds (incl. fenders) which tells me they fit. Are the front and rear x-members the same as well (thru '47 vs. 48 up.) Are the bed sides slightly different as well (indentations, pockets) ?
Also can get pretty decent beds for about $1000 (no rot, brought from out west), but may have to plug fender bolt holes if '48+. Would you guys weld new bottoms on the sides and front, buy x-members (have 1, but ~$180 for other 3) or just bite the bullet and get a decent one ?
P.S. Original bed is in pieces w/rotted x-members long gone (I stripped about 8 yrs. ago).
Might give Northern Classic Trucks - Reproduction parts for your antique Ford truck . a try. They have brand new complete beds for $1750. I have seen their stuff and really like it. Not some cheap knock off stuff. They used to have a link for just bed parts, but I did not see it when I just went on there to get the link. Might want to give them a call and see if they still have bed parts.
Im thinking of getting this bed and filling in the holes like 46yblock did. Any advice or has anyone else used a 50's bed on a 47 half ton?
http://www.ebay.com/itm/120846427410...ht_1027wt_1189
After starting this, I did a lot of research. The specific bed that is referenced does not have the stamped sides like '50 down. Thus, your '42-'47 fenders won't fit properly because they are designed to wrap around the stamp. '48-'50 fenders also have this design, while '51 up are flat, since the beside is also flat. Look at Mack Hills and Northern Classic for a better description and picts.
46yblock used a '49 bed which is the same as '42-47..
The '51 (and some late '50) up beds were fairly similar all the way up to 1972.
Repairing....
https://www.ford-trucks.com/forums/8...way-guide.html
About page 15 is where the fight starts... Then I took a break for the '51. Hope to get back on the '47 in about 3 weeks.
Hey John, it looks like according to the map you are not more than a couple of hours drive from New Alexandria Pa. There is a guy that has a salvage yard there with many parts for the 46-47. J.T.s ANTIQUE TRUCKS & VEHICLES maybe he has what you need. check it out.
Thanks, been to JT's in my decision process (from Projects - 47 1/2T)
"Went to look at the beds JT had in New Alexandria, PA (about 10 '42-47, 3 or 4 more 48-50). For the price $850-$1250, I didn't see a lot of time or $ savings. Most had a little rust holes popping through and the front panels never survive the 65 or so years very well (water always drained poorly if facing downhill and if in a snow region, always packing into the seam against the bed.) So I'm gonna redo mine and maybe get a re-popped front." (08-11-2011)
JT has a lot of stuff, and some great starter projects. Also, If I was starting with nothing, then I would have jumped on what JT had to offer!!
John, Thanks for letting me know about JT's, I was thinking about driving up there to check out what he has. Now I think I will go ahead and get a complete bed from Northern Classic trucks. Its tough to come up with the price but its complete with bed wood and you can get stainless hardware and strips. I have purchased many cab parts from them and have been satisfied with everything.
ericford1984
10-05-2011 09:30 PM
COMPLIT1107
06-25-2011 12:53 PM
Gwilkrrs
17
02-25-2008 07:46 PM
Kai
12-30-2002 04:03 PM
