2003 Rear Differential Fluid Type? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 06-25-2011, 08:37 AM
daveplot's Avatar
daveplot daveplot is offline
daveplot is starting off with a positive reputation.
I need to top off the fluid in my rear differential, what's the recommeneded type for a 2003?
Old 06-25-2011, 08:45 AM
daveplot's Avatar
Found in the Ford Service DVD 75w-140... that still the recomendation?
Old 06-25-2011, 03:46 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Originally Posted by daveplot View Post
Found in the Ford Service DVD 75w-140... that still the recommendation?
According to your owner's manual, it's 75W-140 synthetic if you have a limited slip rear axle. For the non-limited slip rear axle you would use 75W-90 synthetic.
Old 06-26-2011, 09:00 AM
broncoholic's Avatar
broncoholic broncoholic is offline
broncoholic is gaining momentum as a positive member of FTE.
Don't top it off just because it's "low". The fluid level is supposed to be a certain measurement below the fill hole. I don't remember the measurement, but it should be in that dvd service manual you have.
Old 06-26-2011, 09:33 AM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Right. The 9.75" rear diff calls for SYNTHETIC SAE 75W-140 (with or without Traction-Lok).
The 8.8" diff calls for Synthetic SAE 75W-140 with Traction-Lok or non-synthetic SAE 75W-90 without Traction-Lok.
If you have a front diff Ford specs a non-synthetic SAE 75W-90 for the front diff.
Old 06-26-2011, 10:52 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
And if you have the LSD you need modifier, if you do a change.
Old 06-26-2011, 02:00 PM
daveplot's Avatar
Quote:
Thanks, I looked it up, it's 0.9" below the fill hole.
As to the Friction Modifier, one place in the DVD it says XL-7 (as of 4/30/2003) but elsewhere it says XL-3 (as of 1/28/2002). What's the correct Friction Modifier, i'm assuming XL-7 since it has a newer revision date.
Old 06-26-2011, 02:57 PM
I can't find my manual at the moment, but 0.9" sounds excessive, but it may be correct. Make sure that when you looked it up it wasn't 9mm, which would be between 0.3" and 0.4" below the fill hole.
I'm not aware of the difference between the XL-3 and XL-7, but as 1/28/2002 I don't believe Ford had used the IRS in the Expy, so I'd agree with your assumption that XL-7 is correct for the IRS diff.
Old 06-26-2011, 03:52 PM
cdherman cdherman is offline
cdherman is starting off with a positive reputation.
.9" is right for 2004 at least.
My local ford counter man -- pretty large and sucesful place -- says that the 75w140 synth is now standard and superceeds the older heavy diff fluids, regardless what your old manual or shop manual says. He has a ford counter manual that shows that.
So you can run the 75w140 up front too...
Ditto all the comments about needing LSD additive. I have a leaky rear. I've decided to mix up a quart of lube with additive so I can top it off (.9" below) whenever I need to.
And BTW, I too find it just plain stupid for Ford to design a diff case, where you have to use a wire bent like an "L" to find the fluid level. Like -- whatever happend to the good ole days where you filled to level of the filler hole and then you knew you had the right ammount in there......
Old 06-26-2011, 05:06 PM
Quote:
Thanks for the confirmation.
Exactly! And how about the way Ford threatens your warranty if you use the wrong spec fluid, and then all of a sudden its okay (like the Mercon/Mercon V confusion)? Makes one wonder how important their 'spec" is.
Old 06-27-2011, 12:48 AM
ScottyDsntKnow ScottyDsntKnow is offline
ScottyDsntKnow is gaining momentum as a positive member of FTE.ScottyDsntKnow is gaining momentum as a positive member of FTE.
I just do it like I've always done, use a pump to fill through the fill hole until fluid starts to spill out, put the plug back in, done. I've never and have never heard of anyone having a problem doing it this way.
I also run full syn in front and back, 75w-90 front, 75w-140 rear with a tube of friction modifier mixed up in the first quart to go in each of them.
I drained/filled each diff when I first got the vehicle, part of routine maintenance for any used rwd/4wd vehicle I buy. That and the TC/trans fluid and transfer case as well...
edit: and you don't want to "top off" diff fluid. If its low and was filled properly its leaking and needs a new gasket or cover or both. If it isn't leaking it wasn't filled properly. Either way its best to just drain all the old funky fluid out and give your vehicle new fresh stuff that'll last you a while.
Old 06-27-2011, 01:05 PM
whatever happened to the good ole days where you filled to level of the filler hole and then you knew you had the right amount in there......
The reason for the change was cosmetic. When the fluid levels were up at the filler hole, fluid always seemed to ooze out and look unsightly. By lowering the fluid level it kept the fluid away from the filler threads.
Clarification on differential fluid for 2006 Mountaineer please Brewcity Explorer, Sport Trac, Mountaineer & Aviator 5 10-14-2016 03:14 PM
97 F-350 maint question akpolaris 1987 - 1996 F150 & Larger F-Series Trucks 4 10-13-2013 07:55 AM
Front Diff fluid SuperDoodie 1999 - 2003 7.3L Power Stroke Diesel 5 10-21-2011 07:57 PM
Differential Fluid Change onuredneck707 6.0L Power Stroke Diesel 5 03-30-2011 06:09 PM
Rear Differential Fluid Type ALF1999 1999 - 2003 7.3L Power Stroke Diesel 3 05-14-2005 04:44 PM
Tags
03, 2003, axle, clunk, diff, differential, f150, fluid, fluids, ford, leak, lincoln, navigator, noise, rear, xl7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
