How to test injector pigtail
I understand how to ohm test an injector but how do I test the pigtail and harness?
Im getting error code for cylinder F (6) for high/low circuit malfunction. Think it may be inthe pigtail or wires going to cylinder 6. I've also heard if you cross things up you can fry PCM.
I think a continuity test from the pigtail to the PCM could be valuable but how/where can I get a schematic to tell me which wires at the PCM?
Thanks in advance,
Jon
Thanks in advance,
Jon
