Brakes/V10 to Hydro Boost - Ford Truck Enthusiasts Forums
Old 06-24-2011, 09:30 PM
1badton's Avatar
1badton 1badton is offline
1badton is starting off with a positive reputation.
I have a 2000 V10 Excursion. It does not stop as well as my diesel. Has any one tried to convert a V10 to Hydro boost from a diesel. I know it can be done with after market parts,a lot big motor Hot Rods do it because of vacuum problems. So can it be done with oem Hydro booster from like a 7.3? Pics if possible.
Old 06-24-2011, 10:02 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
I also was thinking about this.
Old 01-25-2012, 07:22 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
I cant believe that nobody has done this... The brakes on one of the trucks at work, 05 f350 6.0 4x4, stops 100 times better even with a 4000 lb load of salt in the spreader and the plow on the front. I'd love to have the hydroboost and brakes from an 05+ diesel on my X. ANYONE??????
Old 02-11-2012, 08:02 PM
RACERX7775's Avatar
bump.....really, anyone else compare the stopping power from hydroboost to vacuum brakes in a gas powered X?
Old 02-11-2012, 09:24 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
It's been awhile since I've been on the L boards, but I think a couple of my Lightning brethren converted their brakes to hydro boost.
It's a supercharged 5.4L and not the 6.8L but I can't imagine it would be that different.
I'll do some searches on my old L boards and see if I can find anything relevant.
Stewart
Old 02-11-2012, 09:31 PM
riggers's Avatar
riggers riggers is offline
riggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputationriggers has a superb reputation
which of these does my 7.3 X have? It stops like, well , nothing good.
Old 02-11-2012, 10:16 PM
Stewart_H's Avatar
7.3's have hydro boost because the 7.3 engines don't produce vacuum like gas engines.
What kind of problems are you having with your brakes?
Stewart
Old 02-11-2012, 11:43 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
a bunch of guys with the 70's fords and broncos convert, I'm in that forum and its not that uncommon a mod. Its not rocket science... you just gotta get the booster and run hydro to it. I'm not sure if the power steering off the gas trucks is tapped for it, probably not, so you would probably have to tap it for a new fitting or run some kind of T off the high and low pressure lines for the hydro boost.
Old 02-12-2012, 08:51 AM
MRyanF MRyanF is offline
MRyanF has a good reputation on FTE.MRyanF has a good reputation on FTE.
I did this swap on my Trans Am. It's pretty simple, no need to tap anything just T off the lines. If you can find it at a salvage, get the whole setup with the master, then you just unbolt the Vac booster bolt up the hydro booster and connect the lines. Bleed brakes and your done.
In fact, you probably NEED to get the master because the bore size will likely be different from the Vac booster model.
Old 02-12-2012, 11:42 AM
riggers's Avatar
It just doesn't stop nearly as well as I'd like it to. I may just simply be that I am picky, but it just doesn't stop as fast as I'd like. My hubby's brakes were much faster to stop. And they SQUEAL. Constantly, but someone else told me it's because I live out in the sand and that there is nothing I can do to stop it, they checked my rotors/brakes and everything looked fine so it's not that.
Old 02-12-2012, 12:10 PM
ocboat ocboat is offline
ocboat is gaining momentum as a positive member of FTE.
I also felt like the brakes on my V10 did not stop as well as on my 6.0l so I went ahead and changed my brake pads to EBC yellows stuff even though the old pads still had plenty of life left in them. I am following the bedding instructions which states to use the brakes very lightly for the first 200 miles so I'm not sure if there is any improvement yet. I did not realize that the two trucks had different braking systems and now realize that I may have just wasted some money. I may have to look into the hydroboost swap to get the braking that I am looking for.
Old 08-10-2012, 12:52 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
I know the thread is old but, for anyone wondering if you can hydroboost these trucks with oem parts the answer is yes. I just finished a 2003 X 2 weeks ago using all stock parts.
Get the pressure lines from a 99-04 (order them new) F-450 with the V10 cost is $43.00 for both and are a direct fit.
Get the booster from a 99-04 Diesel F250 F350 F450 F550 or X it bolts right in place of the vacuum booster. Ebay has them for 60-80.00 shipped
Reuse the master cylinder as its the correct one already
Then simply place a brass T in the return line of the reservoir and thats it.
Total time start to finish is about 2.5 hours as the hardest part is pulling the PS pump off to change the hose. Super simple and great upgrade, I am now starting on converting my F150 to hydroboost also using the above parts and so far its all a direct fit.
Old 08-10-2012, 12:15 PM
RACERX7775's Avatar
Thats totally awesome. BUT I could have sworn that there was a problem with getting one of the pushrods or something. Again it was something that didnt come with a new unit and cant get it from the dealer unless you buy the entire unit.I never realized that the 450 and 550 v10 trucks came with hydroboost. im going to the dealer today. THANKS FOR THE WRITEUP. REPS TO YOU. Hows the difference. Doss it stop better or does the pedal just feel firmer?
Old 08-10-2012, 09:43 PM
1badton's Avatar
I posted the ? Awhile back. Just got the email about all the comments. Thanks for all the info.
Old 08-11-2012, 12:28 PM
OleGrouch's Avatar
OleGrouch OleGrouch is offline
OleGrouch is starting off with a positive reputation.
Can I assume this will work on my 01 EX V-10 ? And here I thought I had power brakes already, is this not so ?
Hydro Boost pressure Hose robert kelsey Excursion - King of SUVs 6 03-08-2016 11:16 PM
No hydro boost on 2016 f350? troverman 1999 to 2016 Super Duty 8 11-16-2015 07:25 PM
power streering flush on non hydro boost ?? rkloehn 1999 to 2016 Super Duty 1 08-19-2015 08:59 PM
Hydro-boost vs. vacuum boost mach8274 6.7L Power Stroke Diesel 36 04-22-2012 12:28 PM
Hydro-Boost or no Hydro-Boost? eicht 1999 to 2016 Super Duty 12 05-09-2010 07:09 AM
Tags
05, 06, 2000, 2002, boost, brakes, excursion, f350, ford, hydroboost, hydrobooster, issue, problems, replacement, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
