Brakes/V10 to Hydro Boost
Old 12-27-2013, 08:12 PM
chester8420's Avatar
chester8420
chester8420 is offline
Originally Posted by Stewart_H
You shouldn't have any whine.
Check the fluid level.
Stewart
Fluid is fine. Whine is annoying. I've put over 1,000 miles on it and the whine is relentless. Especially in town or following somebody. I can hear the torque converter lock and unlock letting off the gas and getting back on gently.
  #47
Old 12-27-2013, 08:53 PM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
Just for the heck of it... Are the pumps the same from diesel to gas?
  #48
Old 12-29-2013, 12:48 AM
chester8420
I'm not positive about the year models, but I believe 6.0 and newer they are the same.
7.3's have a pump with built in fluid resevoir.
  #49
Old 12-29-2013, 11:30 PM
chester8420
I've burned several tanks of ethanol through the truck in the past week.
V10 gas Hydroboost conversion = waste of time and money
Summary: Save your money for something more valuable. Like a truck that gets better than 8 or 9mpg.
  #50
Old 01-09-2014, 04:44 PM
GermanMike's Avatar
GermanMike
GermanMike is offline
Just wanted to know if your whining sound of the pump is still there or if its gone do you you know what it causes?
  #51
Old 01-10-2014, 09:57 PM
chester8420
I've put over 2,000 miles on it and the whine is still as loud as ever.
I think it is a consequence of the conversion. I don't think anything in particular is wrong. The hydroboost booster is bolted to the firewall right in front of the steering wheel. I think it is probably just noise that they all make, but the diesel is so loud you can't hear it. If I ever replace the power steering pump, I'll let you know if that fixes it. I'd buy one today if it would cure the "supercharger" syndrome...
  #52
Old 01-11-2014, 12:31 AM
GermanMike's Avatar
GermanMike
Thanks for the update.
Please keep us informed, when something changed.
I was sooooo close to buy all the needed parts. So youre my money saver.
I still think that this conversion is a good idea, but if this issue of you will
happen to every V10 Hydroboost Con. it wont be worth.
We really need a solution for a bigger, better, stronger Servopump.
If we run big tires, have a Hydroboost and maybe feed a hydraulic winch that will let this little piece of crap explode like a grenade.
  #53
Old 01-11-2014, 09:31 PM
RACERX7775's Avatar
RACERX7775
What we need to do is find someone with an f450 v10 and ask if they have the p/s noise. Maybe post in the super duty section...
  #54
Old 01-12-2014, 03:02 AM
GermanMike's Avatar
GermanMike
Its done. Lets see whats will come along......
https://www.ford-trucks.com/forums/1...ost-setup.html
  #55
Old 01-12-2014, 08:53 PM
be250's Avatar
be250
be250 is offline
I have a 04 f450 4x4 ccab v10 auto with hyd brakes ,no noise at all
  #56
Old 01-13-2014, 08:29 AM
RACERX7775's Avatar
RACERX7775
It is hydroboost right? Not the typical vacuum boost. Can you post a pic of the hydroboost unit?
  #57
Old 01-13-2014, 09:40 PM
chester8420
I know this video sucks and my brother called me on the phone, but its all I had time to do. Just turn your speakers up. Photobucket is being a jerk. I hope it works.
http://s48.photobucket.com/user/ches...cfb7a.mp4.html
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid48.photobucket.com %2Falbums%2Ff230%2Fchester8420%2FMVI_0353_zpsb99cf b7a.mp4">
  #58
Old 03-19-2014, 07:10 AM
RKraft's Avatar
RKraft
RKraft is offline
I know this is an old thread but was wondering if any one knows if 06 F350 brake pedal and hydro boost set up will work on our Ex's? I found a used set up with low miles for a good price less than $150.00. Just wondering if it will work and if so I might go for it.
Randy
  #59
Old 10-15-2014, 08:37 PM
chester8420
Randy
Sorry for such a late reply. I very rarely get on the forum. I believe it will work, but I'm not positive. I don't know what year models are the same.
On a side note, it has been over 20,000 miles since I did the conversion. I have since had to make several emergency stops. It will slide the tires, which is something it would NEVER have been able to do before. Before the conversion, I could stand on the pedal with all my might, and it would not even cause the anti locks to come on.... (which are disabled on mine now)
The benefits of the conversion really show when the truck has a heavy payload or pulling a heavy gooseneck trailer. (anything that puts a lot of weight on the front tires)
The stock vacuum brake booster was borderline adequate for an unloaded truck, (it would almost slide the tires) but when there's a lot of extra weight mashing on the front tires, the truck really benefits from the extra braking power of the hydroboost booster. And that's the biggest benefit of the conversion.
Also the power steering "supercharger" whine is still incredibly annoying.
  #60
Old 11-20-2016, 08:42 AM
TSM35's Avatar
TSM35
TSM35 is offline
I know this is old but hopefully the thread will email you.
I am curious why you had to change the pedal assembly. I have adjustable pedals in my 05 X and didn't think I had to change them to add hydroboost.
I've had too many close calls with deer running out in front of me and got in an accident Friday because this thing won't stop. My SD diesel truck stops like a race car. Exact same rotors, pads and calipers.
Also, I had the same whine noise in my F350 after a pump replacement. Bleed by turning the wheels all they way left, hold for a few seconds then do it again right. After doing this a few times it went away. I then flushed the PS with Schaeffer's All Tran fluid and it got even quieter and smoother. You got air in it when you installed the hydroboost.
Quick Reply: Brakes/V10 to Hydro Boost
