Serpentine belt replacement
Old 06-24-2011, 07:54 PM
Headviking's Avatar
Headviking
Headviking is offline
Just finished replacing my serpentine belt. Took about 1 hour to finish. Did some reading here and found some good advice. The locking pin to hold the tensioner was the key. Used a 1/2 drive ratchet and a 2ft pipe for leverage. Pulled up towards the centre of the engine with my right hand and with my left reached down and with a finger pushed up to the right the locking pin and slowly released the tension on the ratchet. The belt was loose. I made a diagram of the way the belt was routed. Good thing because the diagram on the fan shroud was incorrect. I will leave a copy of the routing in my glove box, incase I ever need it again. Took about a half dozen times, up on top and down under the front to finally route it correctly. Found that if you feed the belt from the top and route the crank first the rest will go in easier.
Anyway thought I would post this for others to go ahead and replace there belts. My truck has 155,000 klm on her (96,000 miles).
Old 06-24-2011, 10:24 PM
flamebuster's Avatar
flamebuster
flamebuster is offline
Ford has got to hold the record for the most difficult belt change... But I guess it is still better than all those v belts we use to have to change.....lol..
Old 06-24-2011, 10:29 PM
djanzen's Avatar
djanzen
djanzen is offline
NO I have changed a couple of 24v cummins they are a nightmare!
Old 06-24-2011, 10:57 PM
27ModelT's Avatar
27ModelT
27ModelT is offline
Is there a trick to get a 1/2 inch rachet to fit on the idler? I can't get a rachet to fit in that tight of a space.
Old 06-24-2011, 10:58 PM
zhilton's Avatar
zhilton
zhilton is offline
My wife drives an Odyssey..there is at least two different belts on that transverse mounted thing. Neither one looks like it will be fun to change when the time comes.
Old 06-24-2011, 11:11 PM
Headviking's Avatar
Headviking
No trick just slightly tilted.
Old 06-25-2011, 01:17 AM
sammy77's Avatar
sammy77
sammy77 is offline
Crap I just remembered I gotta tackle this soon. I thought you had to remove fan shroud and all to do the belt. That's great to hear
Old 06-25-2011, 08:14 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
I pulled that small extension piece off the top of the shroud to get a little more room. It's pretty easy - just some tabs behind the rubber seal where it meets the shroud. Several guys have said don't bother with it but I couldn't even see the tensioner before I pulled it.
Old 06-25-2011, 10:50 AM
Headviking's Avatar
Headviking
One more thing to add. I had to remove the air/fan deflector to be able to reach in.
Old 06-25-2011, 12:33 PM
MudhenGIB's Avatar
MudhenGIB
MudhenGIB is offline
I purchased a tool specially designed for this job. I keep it, and a spare belt, in the truck. The tool makes it easier. I don't remember the name of the company who made said tool.
Old 06-25-2011, 12:50 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I just pull on the belt and flip up kickstand on belt tensioner no tools at all
give it a hard pull you can do it
Old 06-25-2011, 02:22 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
When I did mine on my 24V Cummins, it wasnt that hard.
Old 06-25-2011, 04:39 PM
27ModelT's Avatar
27ModelT
27ModelT is offline
Great advice!! Thanks.
Old 06-25-2011, 04:59 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
I shouldn't really be posting this, but you don't even need a ratchet. I just use my bare hands, and grab the belt between the alternator and the idler pulley on the tensioner, and give it a real hard YANK, while reaching underneath with the other hand to push the lock tab in. Although, belt and tensioner failures on 6.0L engines tend to be extremely rare. 7.3L belt tensioners are a different story though. Ditto for the primary drive belt tensioner on a 6.4L.
Old 10-08-2011, 11:47 AM
stangclassic66's Avatar
stangclassic66
stangclassic66 is offline
Just did this 5 mins ago. Took me 30 mins thanks to this thread! I'm a firm believer in not bumping old threads, but tech threads like this are an exception! Thanks guys!! Thank god it wasn't the belt tensioner!
Quick Reply: Serpentine belt replacement
