AOD slams into gear
AOD slams into gear
Hello, I have a 1990 F-150 with a 5.0 and AOD. The truck was running fine for a very long time. The issue has been this, once you put the truck into gear from park or any forward or reverse gear the truck jumps and if you let off the brake it will go 15mph without giving it any gas. The RPM's is at 1200. When trying to slow down, I have to exert a lot of force on the brake pedal and the truck will dog down until 600 RPMs and then it will stop and then it will idle fine.
I have got the truck idle very smooth. However still when the truck is put into gear it slams. It does so more when the truck warms up and driven. It shifts at the correct rpm's, however it feels as if the torque converter is locked up all the time. When it shifts from 1st to second and into drive the truck has little power until the rpms are above 3k or a higher speed just like shifting a manual transmission from 3rd to 5th. Could this possible the condition of a locked up torque converter or something else in the transmission? I am currently using TCI brand mercon V fluid.
LARIAT 85
'80-'86 HOWTO's
28
07-07-2022 03:50 PM
nolan62
15
11-27-2016 01:47 PM
nastruk95
07-30-2015 11:25 AM
ladiabla74
03-19-2004 07:05 AM
