Best 6.0 Oil?? - Ford Truck Enthusiasts Forums
Best 6.0 Oil??
Old 06-24-2011, 12:26 AM
SNIPER168308 SNIPER168308 is offline
SNIPER168308 is starting off with a positive reputation.
Best 6.0 Oil??
I now own my first 6.0.... What's the best oil to run in it... I've been told to ONLY use Ford PSD oil for 6.0 and not to run Rotella (aerates to easily), is this true or BS?
I run Rotella Synthetic in my 7.3 w/o any issues and I know others who use Mobile Syn Diesel oil.... Just want to run the best so I get logevity outta the 6.0
Old 06-24-2011, 01:05 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is gaining momentum as a positive member of FTE.
Mobil-1 turbo diesel truck oil. Nothing else will do for me.
Old 06-24-2011, 04:05 AM
XB70 XB70 is offline
XB70 has a good reputation on FTE.XB70 has a good reputation on FTE.
Find the person who told you never to use Rotella in a 6.0. Take a picture of him and write down his address so you never forget him. Now, run Forrest, run away from that evil stupid man!
Mobil 1 for Turbo Diesel Trucks is a fine oil as is Shell Rotella T6. I used TDT back when it was the same formula as Mobil Delvac 1.
Delvac 1 is probably the best diesel engine oil, but it's expensive. I consider Mobil 1 for turbo diesel trucks and Shell Rotella functionally equivalent. Both show excellent performance in 6.0 engines. You can buy a gallon of T6 at Walmart for $20.56.
I don't use Delvac 1 simply because running extended oil change is a really poor idea. Group IV synthetics like Delvac 1 make economic sense for long change intervals. Less expensive Group III + oils like TDT and T6 give you the cold start / cold weather benefits and w40 high temperature performance without the extra cost of a long oil change interval Group IV oil being dumped every 5,000 or 7,500 miles.
Old 06-24-2011, 05:50 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Lots of people running Rotella T6 and liking it.
Old 06-24-2011, 06:04 AM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
This thread will be three pages long before the weekend is over..
Personally, I've been running Mystic JT8 synthetic blend 15W40 late spring to late fall (warm months) for almost 70k miles. At $12 gallon at my local farm & ranch stores, and meeting the CJ4 requirements...I'm happy and the truck is happy.
Old 06-24-2011, 08:09 AM
egregg57's Avatar
egregg57 egregg57 is offline
egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.
I have been using Rotella T6. I am very happy with it. Ford diesel mechanic suggested it as a good product. His 23 years working on diesels speaks volumes for me.
Old 06-24-2011, 09:11 AM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Any major brand with the CI4 plus rating or higher will work fine. I'm currently using Valvoline Premium Blue 5W40. Napa had a sale on it. I've also used the T-6 with excellant results.
Old 06-24-2011, 10:44 PM
I just read that Ford says it's Diesel Syn Oil can be used in temps from -20 to 100deg.. I also read a couple posts where there was concern about using a 5w40 Syn in temps above 90 deg..
I really don't want to worry about changing oil with the seasons... If Rotella Syn CJ fits the bill, that's what I'll run..(my 7.3 likes it year round).. I know the 6.0 is a different beast, so I want to be damn sure what I need to use in it...
Old 06-24-2011, 11:04 PM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
The Rotella "aerates too easily" was an issue with rotella when Ford came out with the 7.3 psd with the HEUI injection system, but was fixed soon after. Funny how people still think this is a problem after +15 years.
More important than brand is to use a CJ4 rated oil and change it every 5k miles. My personnel belief of which oil is the best is Mobile Delvac. It uses some of the best additives and holds it viscosity better than the big 3. It returns some stellar OUA and is second to none for engine cleanliness. It's defitely a sleeper oil.
Old 06-24-2011, 11:49 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
Quote:
I use it and haven't had any issues. At 5k mile ooil changes it can get expensive but if you look for sales and stock up you can save up to 6-7.00 a gallon.
Old 06-24-2011, 11:54 PM
bismic's Avatar
I am using it w/ a bottle of ZDDP - getting good UOA. My high-ish iron number that began w/ the Valvoline PBE is even coming down.
Old 06-27-2011, 01:34 PM
AGE mechanic AGE mechanic is offline
AGE mechanic is gaining momentum as a positive member of FTE.
Amsoil, is what I have used in ALL my stuff for the last 10 years. Truck runs great, Harley runs great and both Toyotas run great.
Old 06-27-2011, 04:44 PM
sarnott140 sarnott140 is offline
sarnott140 is starting off with a positive reputation.
0w40 synthetic year round for me
Old 06-27-2011, 05:42 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
mobil 1 so far, I will soon switch and see how the oil analysis changes on 8,000mile intervals I do.
Old 06-27-2011, 06:11 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
I've been using the Motorcraft 15w-40. Thinking I'll use a synthetic next oil change. I think I have a little striction going on and thinking the 5w might help some on cold start. On the hot side of the coin though, high temps have been bumping 100+ around here lately. Is there a synth that will work well on both extremes?
Shell Rotella ELC coolant fordtruckrodder 6.0L Power Stroke Diesel 8 Yesterday 12:04 PM
Best Diesel Oil? PSD6litre40 6.0L Power Stroke Diesel 79 12-26-2013 06:42 PM
5w-40 Rotella Synthetic Thought's Suggestion's tankd72 6.0L Power Stroke Diesel 109 11-14-2013 06:44 PM
BEST OIL FOR A 6.0 STOCK06 General Diesel Discussion 18 01-15-2013 06:05 AM
Rotella T Full Syn Bad for 6.0 Injectors??? jayc3169 6.0L Power Stroke Diesel 17 07-18-2010 08:42 PM
Tags
60, brands, diesel, duty, ford, mobil, oil, recommended, rotella, shell, super, t6, truck, turbo, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
