Keyless entry code (instructions and string) - Ford Truck Enthusiasts Forums
Old 06-23-2011, 10:58 PM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
Thumbs up Keyless entry code (instructions and string)
Figured I would put this all in one post to make it easy.
Some models have the keypad on a sticker behind the stereo or other areas. *I have found this is only true on (possibly) 2002 and newer (was not on my 2000).
While searching the forums for the code and instructions it took me a long time. *Maybe the moderator could sticky this version to make future searches easier?
First, the instructions, then below is the string of numbers to enter.
Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Programming Your Own Personal Entry Code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.*
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.*
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing Your Personal Code or A Prior Owner's Code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the Doors
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the Doors
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
Now, the string to enter. *Don't be intimidated, it is actually easy and takes most people about 10-15 minutes to do. *Well worth it considering most dealers charge over $100 to hook it to the computer.
9 9 9 9 1 1 1 1 1 3 1 1 1 1 5 1 1 1 1 7 1 1 1 1 9 1 1 1 3 3 1 1 1 3 5 1 1 1 3 7 1 1 1 3 9 1 1 1 5 3 1 1 1 5 5 1 1 1 5 7 1 1 1 5 9 1 1 1 7 3 1 1 1 7 5 1 1 1 7 7 1 1 1 7 9 1 1 1 9 3 1 1 1 9 5 1 1 1 9 7 1 1 1 9 9 1 1 3 1 3 1 1 3 1 5 1 1 3 1 7 1 1 3 1 9 1 1 3 3 3 1 1 3 3 5 1 1 3 3 7 1 1 3 3 9 1 1 3 5 3 1 1 3 5 5 1 1 3 5 7 1 1 3 5 9 1 1 3 7 3 1 1 3 7 5 1 1 3 7 7 1 1 3 7 9 1 1 3 9 3 1 1 3 9 5 1 1 3 9 7 1 1 3 9 9 1 1 5 1 3 1 1 5 1 5 1 1 5 1 7 1 1 5 1 9 1 1 5 3 3 1 1 5 3 5 1 1 5 3 7 1 1 5 3 9 1 1 5 5 3 1 1 5 5 5 1 1 5 5 7 1 1 5 5 9 1 1 5 7 3 1 1 5 7 5 1 1 5 7 7 1 1 5 7 9 1 1 5 9 3 1 1 5 9 5 1 1 5 9 7 1 1 5 9 9 1 1 7 1 3 1 1 7 1 5 1 1 7 1 7 1 1 7 1 9 1 1 7 3 3 1 1 7 3 5 1 1 7 3 7 1 1 7 3 9 1 1 7 5 3 1 1 7 5 5 1 1 7 5 7 1 1 7 5 9 1 1 7 7 3 1 1 7 7 5 1 1 7 7 7 1 1 7 7 9 1 1 7 9 3 1 1 7 9 5 1 1 7 9 7 1 1 7 9 9 1 1 9 1 3 1 1 9 1 5 1 1 9 1 7 1 1 9 1 9 1 1 9 3 3 1 1 9 3 5 1 1 9 3 7 1 1 9 3 9 1 1 9 5 3 1 1 9 5 5 1 1 9 5 7 1 1 9 5 9 1 1 9 7 3 1 1 9 7 5 1 1 9 7 7 1 1 9 7 9 1 1 9 9 3 1 1 9 9 5 1 1 9 9 7 1 1 9 9 9 1 3 1 3 3 1 3 1 3 5 1 3 1 3 7 1 3 1 3 9 1 3 1 5 3 1 3 1 5 5 1 3 1 5 7 1 3 1 5 9 1 3 1 7 3 1 3 1 7 5 1 3 1 7 7 1 3 1 7 9 1 3 1 9 3 1 3 1 9 5 1 3 1 9 7 1 3 1 9 9 1 3 3 1 5 1 3 3 1 7 1 3 3 1 9 1 3 3 3 3 1 3 3 3 5 1 3 3 3 7 1 3 3 3 9 1 3 3 5 3 1 3 3 5 5 1 3 3 5 7 1 3 3 5 9 1 3 3 7 3 1 3 3 7 5 1 3 3 7 7 1 3 3 7 9 1 3 3 9 3 1 3 3 9 5 1 3 3 9 7 1 3 3 9 9 1 3 5 1 5 1 3 5 1 7 1 3 5 1 9 1 3 5 3 3 1 3 5 3 5 1 3 5 3 7 1 3 5 3 9 1 3 5 5 3 1 3 5 5 5 1 3 5 5 7 1 3 5 5 9 1 3 5 7 3 1 3 5 7 5 1 3 5 7 7 1 3 5 7 9 1 3 5 9 3 1 3 5 9 5 1 3 5 9 7 1 3 5 9 9 1 3 7 1 5 1 3 7 1 7 1 3 7 1 9 1 3 7 3 3 1 3 7 3 5 1 3 7 3 7 1 3 7 3 9 1 3 7 5 3 1 3 7 5 5 1 3 7 5 7 1 3 7 5 9 1 3 7 7 3 1 3 7 7 5 1 3 7 7 7 1 3 7 7 9 1 3 7 9 3 1 3 7 9 5 1 3 7 9 7 1 3 7 9 9 1 3 9 1 5 1 3 9 1 7 1 3 9 1 9 1 3 9 3 3 1 3 9 3 5 1 3 9 3 7 1 3 9 3 9 1 3 9 5 3 1 3 9 5 5 1 3 9 5 7 1 3 9 5 9 1 3 9 7 3 1 3 9 7 5 1 3 9 7 7 1 3 9 7 9 1 3 9 9 3 1 3 9 9 5 1 3 9 9 7 1 3 9 9 9 1 5 1 5 3 1 5 1 5 5 1 5 1 5 7 1 5 1 5 9 1 5 1 7 3 1 5 1 7 5 1 5 1 7 7 1 5 1 7 9 1 5 1 9 3 1 5 1 9 5 1 5 1 9 7 1 5 1 9 9 1 5 3 1 7 1 5 3 1 9 1 5 3 3 3 1 5 3 3 5 1 5 3 3 7 1 5 3 3 9 1 5 3 5 3 1 5 3 5 5 1 5 3 5 7 1 5 3 5 9 1 5 3 7 3 1 5 3 7 5 1 5 3 7 7 1 5 3 7 9 1 5 3 9 3 1 5 3 9 5 1 5 3 9 7 1 5 3 9 9 1 5 5 1 7 1 5 5 1 9 1 5 5 3 3 1 5 5 3 5 1 5 5 3 7 1 5 5 3 9 1 5 5 5 3 1 5 5 5 5 1 5 5 5 7 1 5 5 5 9 1 5 5 7 3 1 5 5 7 5 1 5 5 7 7 1 5 5 7 9 1 5 5 9 3 1 5 5 9 5 1 5 5 9 7 1 5 5 9 9 1 5 7 1 7 1 5 7 1 9 1 5 7 3 3 1 5 7 3 5 1 5 7 3 7 1 5 7 3 9 1 5 7 5 3 1 5 7 5 5 1 5 7 5 7 1 5 7 5 9 1 5 7 7 3 1 5 7 7 5 1 5 7 7 7 1 5 7 7 9 1 5 7 9 3 1 5 7 9 5 1 5 7 9 7 1 5 7 9 9 1 5 9 1 7 1 5 9 1 9 1 5 9 3 3 1 5 9 3 5 1 5 9 3 7 1 5 9 3 9 1 5 9 5 3 1 5 9 5 5 1 5 9 5 7 1 5 9 5 9 1 5 9 7 3 1 5 9 7 5 1 5 9 7 7 1 5 9 7 9 1 5 9 9 3 1 5 9 9 5 1 5 9 9 7 1 5 9 9 9 1 7 1 7 3 1 7 1 7 5 1 7 1 7 7 1 7 1 7 9 1 7 1 9 3 1 7 1 9 5 1 7 1 9 7 1 7 1 9 9 1 7 3 1 9 1 7 3 3 3 1 7 3 3 5 1 7 3 3 7 1 7 3 3 9 1 7 3 5 3 1 7 3 5 5 1 7 3 5 7 1 7 3 5 9 1 7 3 7 3 1 7 3 7 5 1 7 3 7 7 1 7 3 7 9 1 7 3 9 3 1 7 3 9 5 1 7 3 9 7 1 7 3 9 9 1 7 5 1 9 1 7 5 3 3 1 7 5 3 5 1 7 5 3 7 1 7 5 3 9 1 7 5 5 3 1 7 5 5 5 1 7 5 5 7 1 7 5 5 9 1 7 5 7 3 1 7 5 7 5 1 7 5 7 7 1 7 5 7 9 1 7 5 9 3 1 7 5 9 5 1 7 5 9 7 1 7 5 9 9 1 7 7 1 9 1 7 7 3 3 1 7 7 3 5 1 7 7 3 7 1 7 7 3 9 1 7 7 5 3 1 7 7 5 5 1 7 7 5 7 1 7 7 5 9 1 7 7 7 3 1 7 7 7 5 1 7 7 7 7 1 7 7 7 9 1 7 7 9 3 1 7 7 9 5 1 7 7 9 7 1 7 7 9 9 1 7 9 1 9 1 7 9 3 3 1 7 9 3 5 1 7 9 3 7 1 7 9 3 9 1 7 9 5 3 1 7 9 5 5 1 7 9 5 7 1 7 9 5 9 1 7 9 7 3 1 7 9 7 5 1 7 9 7 7 1 7 9 7 9 1 7 9 9 3 1 7 9 9 5 1 7 9 9 7 1 7 9 9 9 1 9 1 9 3 1 9 1 9 5 1 9 1 9 7 1 9 1 9 9 1 9 3 3 3 1 9 3 3 5 1 9 3 3 7 1 9 3 3 9 1 9 3 5 3 1 9 3 5 5 1 9 3 5 7 1 9 3 5 9 1 9 3 7 3 1 9 3 7 5 1 9 3 7 7 1 9 3 7 9 1 9 3 9 3 1 9 3 9 5 1 9 3 9 7 1 9 3 9 9 1 9 5 3 3 1 9 5 3 5 1 9 5 3 7 1 9 5 3 9 1 9 5 5 3 1 9 5 5 5 1 9 5 5 7 1 9 5 5 9 1 9 5 7 3 1 9 5 7 5 1 9 5 7 7 1 9 5 7 9 1 9 5 9 3 1 9 5 9 5 1 9 5 9 7 1 9 5 9 9 1 9 7 3 3 1 9 7 3 5 1 9 7 3 7 1 9 7 3 9 1 9 7 5 3 1 9 7 5 5 1 9 7 5 7 1 9 7 5 9 1 9 7 7 3 1 9 7 7 5 1 9 7 7 7 1 9 7 7 9 1 9 7 9 3 1 9 7 9 5 1 9 7 9 7 1 9 7 9 9 1 9 9 3 3 1 9 9 3 5 1 9 9 3 7 1 9 9 3 9 1 9 9 5 3 1 9 9 5 5 1 9 9 5 7 1 9 9 5 9 1 9 9 7 3 1 9 9 7 5 1 9 9 7 7 1 9 9 7 9 1 9 9 9 3 1 9 9 9 5 1 9 9 9 7 1 9 9 9 9 3 3 3 3 3 5 3 3 3 3 7 3 3 3 3 9 3 3 3 5 5 3 3 3 5 7 3 3 3 5 9 3 3 3 7 5 3 3 3 7 7 3 3 3 7 9 3 3 3 9 5 3 3 3 9 7 3 3 3 9 9 3 3 5 3 5 3 3 5 3 7 3 3 5 3 9 3 3 5 5 5 3 3 5 5 7 3 3 5 5 9 3 3 5 7 5 3 3 5 7 7 3 3 5 7 9 3 3 5 9 5 3 3 5 9 7 3 3 5 9 9 3 3 7 3 5 3 3 7 3 7 3 3 7 3 9 3 3 7 5 5 3 3 7 5 7 3 3 7 5 9 3 3 7 7 5 3 3 7 7 7 3 3 7 7 9 3 3 7 9 5 3 3 7 9 7 3 3 7 9 9 3 3 9 3 5 3 3 9 3 7 3 3 9 3 9 3 3 9 5 5 3 3 9 5 7 3 3 9 5 9 3 3 9 7 5 3 3 9 7 7 3 3 9 7 9 3 3 9 9 5 3 3 9 9 7 3 3 9 9 9 3 5 3 5 5 3 5 3 5 7 3 5 3 5 9 3 5 3 7 5 3 5 3 7 7 3 5 3 7 9 3 5 3 9 5 3 5 3 9 7 3 5 3 9 9 3 5 5 3 7 3 5 5 3 9 3 5 5 5 5 3 5 5 5 7 3 5 5 5 9 3 5 5 7 5 3 5 5 7 7 3 5 5 7 9 3 5 5 9 5 3 5 5 9 7 3 5 5 9 9 3 5 7 3 7 3 5 7 3 9 3 5 7 5 5 3 5 7 5 7 3 5 7 5 9 3 5 7 7 5 3 5 7 7 7 3 5 7 7 9 3 5 7 9 5 3 5 7 9 7 3 5 7 9 9 3 5 9 3 7 3 5 9 3 9 3 5 9 5 5 3 5 9 5 7 3 5 9 5 9 3 5 9 7 5 3 5 9 7 7 3 5 9 7 9 3 5 9 9 5 3 5 9 9 7 3 5 9 9 9 3 7 3 7 5 3 7 3 7 7 3 7 3 7 9 3 7 3 9 5 3 7 3 9 7 3 7 3 9 9 3 7 5 3 9 3 7 5 5 5 3 7 5 5 7 3 7 5 5 9 3 7 5 7 5 3 7 5 7 7 3 7 5 7 9 3 7 5 9 5 3 7 5 9 7 3 7 5 9 9 3 7 7 3 9 3 7 7 5 5 3 7 7 5 7 3 7 7 5 9 3 7 7 7 5 3 7 7 7 7 3 7 7 7 9 3 7 7 9 5 3 7 7 9 7 3 7 7 9 9 3 7 9 3 9 3 7 9 5 5 3 7 9 5 7 3 7 9 5 9 3 7 9 7 5 3 7 9 7 7 3 7 9 7 9 3 7 9 9 5 3 7 9 9 7 3 7 9 9 9 3 9 3 9 5 3 9 3 9 7 3 9 3 9 9 3 9 5 5 5 3 9 5 5 7 3 9 5 5 9 3 9 5 7 5 3 9 5 7 7 3 9 5 7 9 3 9 5 9 5 3 9 5 9 7 3 9 5 9 9 3 9 7 5 5 3 9 7 5 7 3 9 7 5 9 3 9 7 7 5 3 9 7 7 7 3 9 7 7 9 3 9 7 9 5 3 9 7 9 7 3 9 7 9 9 3 9 9 5 5 3 9 9 5 7 3 9 9 5 9 3 9 9 7 5 3 9 9 7 7 3 9 9 7 9 3 9 9 9 5 3 9 9 9 7 3 9 9 9 9 5 5 5 5 5 7 5 5 5 5 9 5 5 5 7 7 5 5 5 7 9 5 5 5 9 7 5 5 5 9 9 5 5 7 5 7 5 5 7 5 9 5 5 7 7 7 5 5 7 7 9 5 5 7 9 7 5 5 7 9 9 5 5 9 5 7 5 5 9 5 9 5 5 9 7 7 5 5 9 7 9 5 5 9 9 7 5 5 9 9 9 5 7 5 7 7 5 7 5 7 9 5 7 5 9 7 5 7 5 9 9 5 7 7 5 9 5 7 7 7 7 5 7 7 7 9 5 7 7 9 7 5 7 7 9 9 5 7 9 5 9 5 7 9 7 7 5 7 9 7 9 5 7 9 9 7 5 7 9 9 9 5 9 5 9 7 5 9 5 9 9 5 9 7 7 7 5 9 7 7 9 5 9 7 9 7 5 9 7 9 9 5 9 9 7 7 5 9 9 7 9 5 9 9 9 7 5 9 9 9 9 7 7 7 7 7 9 7 7 7 9 9 7 7 9 7 9 7 7 9 9 9 7 9 7 9 9 7 9 9 9 9 9
Old 06-24-2011, 12:38 AM
sandcon sandcon is offline
sandcon is starting off with a positive reputation.
Hey robert,can you explain how to enter the string? I locked the doors and began to enter the string left to right and half way across the page the lights flashed and the theft light came. Had to turn it off with the key
Old 06-24-2011, 02:29 AM
If I remember correctly, newer models (2002 and newer?) disable the keypad after something like 35 keystrokes. The fast way I know around it is what you did - reset via key...the slow way is to wait 1 minute.
Someone smarter than myself broke the string into groups to make it easy to find 35 digits. Remember, if you key in 20 digits, the last 5 open the door, so when you hit number 35, go back 4 or 5 numbers when you continue.
Oh, one last part...the first number that works MAY be the prior owners code. If you keep going you will probably hit a second code that works (how mine ended up playing out). I tried resetting the first code and it ended up being the personal code. I would keep going after the first code if your truck is a 2000 or 2001 and resetting the first code you find doesn't work -it means you are not using the "master" code for your truck. If you have a 2002 or newer, it's a 50/50 chance you hit the master code first and can erase the personal code without even knowing the code you are erasing. Clear as mud?
99991 11113 11115 11117 11119 11133 11135 11137
11139 11153 11155 11157 11159 11173 11175 11177
11179 11193 11195 11197 11199 11313 11315 11317
11319 11333 11335 11337 11339 11353 11355 11357
11359 11373 11375 11377 11379 11393 11395 11397
11399 11513 11515 11517 11519 11533 11535 11537
11539 11553 11555 11557 11559 11573 11575 11577
11579 11593 11595 11597 11599 11713 11715 11717
11719 11733 11735 11737 11739 11753 11755 11757
11759 11773 11775 11777 11779 11793 11795 11797
11799 11913 11915 11917 11919 11933 11935 11937
11939 11953 11955 11957 11959 11973 11975 11977
11979 11993 11995 11997 11999 13133 13135 13137
13139 13153 13155 13157 13159 13173 13175 13177
13179 13193 13195 13197 13199 13315 13317 13319
13333 13335 13337 13339 13353 13355 13357 13359
13373 13375 13377 13379 13393 13395 13397 13399
13515 13517 13519 13533 13535 13537 13539 13553
13555 13557 13559 13573 13575 13577 13579 13593
13595 13597 13599 13715 13717 13719 13733 13735
13737 13739 13753 13755 13757 13759 13773 13775
13777 13779 13793 13795 13797 13799 13915 13917
13919 13933 13935 13937 13939 13953 13955 13957
13959 13973 13975 13977 13979 13993 13995 13997
13999 15153 15155 15157 15159 15173 15175 15177
15179 15193 15195 15197 15199 15317 15319 15333
15335 15337 15339 15353 15355 15357 15359 15373
15375 15377 15379 15393 15395 15397 15399 15517
15519 15533 15535 15537 15539 15553 15555 15557
15559 15573 15575 15577 15579 15593 15595 15597
15599 15717 15719 15733 15735 15737 15739 15753
15755 15757 15759 15773 15775 15777 15779 15793
15795 15797 15799 15917 15919 15933 15935 15937
15939 15953 15955 15957 15959 15973 15975 15977
15979 15993 15995 15997 15999 17173 17175 17177
17179 17193 17195 17197 17199 17319 17333 17335
17337 17339 17353 17355 17357 17359 17373 17375
17377 17379 17393 17395 17397 17399 17519 17533
17535 17537 17539 17553 17555 17557 17559 17573
17575 17577 17579 17593 17595 17597 17599 17719
17733 17735 17737 17739 17753 17755 17757 17759
17773 17775 17777 17779 17793 17795 17797 17799
17919 17933 17935 17937 17939 17953 17955 17957
17959 17973 17975 17977 17979 17993 17995 17997
17999 19193 19195 19197 19199 19333 19335 19337
19339 19353 19355 19357 19359 19373 19375 19377
19379 19393 19395 19397 19399 19533 19535 19537
19539 19553 19555 19557 19559 19573 19575 19577
19579 19593 19595 19597 19599 19733 19735 19737
19739 19753 19755 19757 19759 19773 19775 19777
19779 19793 19795 19797 19799 19933 19935 19937
19939 19953 19955 19957 19959 19973 19975 19977
19979 19993 19995 19997 19999 33333 53333 73333
93335 53335 73335 93337 53337 73337 93339 53339
73339 93353 53353 73353 93355 53355 73355 93357
53357 73357 93359 53359 73359 93373 53373 73373
93375 53375 73375 93377 53377 73377 93379 53379
73379 93393 53393 73393 93395 53395 73395 93397
53397 73397 93399 53399 73399 93535 53535 73535
93537 53537 73537 93539 53539 73539 93553 73553
93555 53555 73555 93557 53557 73557 93559 53559
73559 93573 73573 93575 53575 73575 93577 53577
73577 93579 53579 73579 93593 73593 93595 53595
73595 93597 53597 73597 93599 53599 73599 93737
53737 73737 93739 53739 73739 93753 93755 53755
73755 93757 53757 73757 93759 53759 73759 93773
93775 53775 73775 93777 53777 73777 93779 53779
73779 93793 93795 53795 73795 93797 53797 73797
93799 53799 73799 93939 53939 73939 93955 53955
73955 93957 53957 73957 93959 53959 73959 93975
53975 73975 93977 53977 73977 93979 53979 73979
93995 53995 73995 93997 53997 73997 93999 53999
73999 95555 57555 59555 77555 79555 97555 99557
57557 59557 77557 79557 97557 99559 57559 59559
77559 79559 97559 99575 77575 79575 97575 99577
59577 77577 79577 97577 99579 59579 77579 79579
97579 99595 97595 99597 77597 79597 97597 99599
77599 79599 97599 99777 77977 79977 97977 99979
79979 9999
Old 11-17-2011, 09:11 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Quote:
wow thats gonna take a while without messing up
Old 11-17-2011, 09:14 PM
79979 9999
Try this set. Remember, you probably won't have to enter all of them, unless your keypad code is 99999.
I did this on mine and it took maybe 10, 15 minutes max to find both codes.
Old 11-17-2011, 09:20 PM
Quote:
So you have a model newer that only lets you do so many key strokes until it "locks" the keypad out (to deter thieves from doing exactly what we are trying).
There is no way around other than the key on/key off (or you could wait it out, but it's shorter to use the key).
If you don't have the patience supposedly they code is on a box behind the stereo area (visible if you pull off the fuse panel and look up to the center of the dash towards the stereo area). Not everyone has had success finding it there.
If your stealership is a PITA like my local one is, you would have to pay around $60 or so to download it from the computer. You may have a nice one like some other lucky folks that would do it for less or even free.
Since mine is a 2000 I could just enter the code straight from the paper and it was done quickly, I might be singing a different tune if I had to stop every 30 or 35 presses. Maybe have a helper inside who can turn the key on and off when you signal...
But to answer your question, when it stops responding, you have to go back 4 digits, reset, and start at that digit 4 back (since the last 5 were enough to trip the lockout you can assume that ISN'T the code).
Remember, on yours once you find the code, go back to my post and see if it lets you clear/change...that means you have the "master" code (a 50/50 chance you may). If it doesn't, KEEP GOING so you can find your master code.
Old 11-17-2011, 09:26 PM
A test for all of you
I rolled down my window and tested to see if the lock/unlock features worked with the keys in/engine on and it did. Wondering if the newer models also allow this...
Old 02-05-2012, 08:49 PM
ddivinia ddivinia is offline
ddivinia is gaining momentum as a positive member of FTE.ddivinia is gaining momentum as a positive member of FTE.
Outstanding - i have my code now.
This thread should be in a sticky or tech.
What is auto-lock?
D.
Old 02-05-2012, 09:39 PM
Fuha's Avatar
Fuha Fuha is offline
Fuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputationFuha has a superb reputation
Unlocking the Doors
Locking the Doors
Printed... 1....2....3... here i go!!
Old 02-05-2012, 09:40 PM
It went quicker than I figured it would. I had it within 5 mins.
D.
Old 02-05-2012, 09:49 PM
What is auto-lock?
D.
I shouldn't have used that term..."auto lock" is the feature that locks the doors once you hit a specific speed. What I was testing was could you start the truck, lock and shut the doors, then open the doors while the truck was running via the keypad.
The answer is yes, you can. For me it's fantastic...when I'm on a call or training, I can leave my rig running, lock the doors so no-one can drive away with it but I can still keep the internal computer, inverter and radios running without worrying about killing the battery.
The 2000 doesn't have the actual "auto-lock" feature.
Old 02-05-2012, 11:28 PM
Fuha's Avatar
Ding Ding Ding.. I have a winner!! Factory code was the first one I found. Setup personal code and trashed the sheet. Thanks. I was taking it to the dealer on Tuesday to get the code. Now I can do something else to it.
Old 02-06-2012, 01:30 AM
Quote:
If you have a 2000, I'd suggest the next thing you do is an alarm. That keyless code string that someone graciously posted way back when is available for anyone to find. Once they find it, they can 'break' into your car just the same way you just did and steal everything in it. An alarm will at least let you hear it when they do it...
Old 03-28-2012, 01:57 PM
SMIGGS's Avatar
SMIGGS SMIGGS is offline
SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.SMIGGS has a great reputation on FTE.
Awesome thread! I haven't tried it but printed the codes and on my way to pick up a cold case of beer and give it a go!
Thanks!
Old 03-28-2012, 07:22 PM
Rosson03's Avatar
Rosson03 Rosson03 is offline
Rosson03 is gaining momentum as a positive member of FTE.Rosson03 is gaining momentum as a positive member of FTE.
Unlocking the Doors
Locking the Doors
bever dam. my code is in there!! how u figure is out!
Keyless Keypad Code xTraveler Excursion - King of SUVs 746 02-11-2017 10:29 PM
Bridgeport in the fall-just a bunch of pics bpounds S. California Chapter 4 10-26-2016 09:06 PM
how to find the keypad code article/ post jnobles06 6.0L Power Stroke Diesel 19 06-27-2016 10:08 AM
Keypad does not unlock the doors Spades Explorer, Sport Trac, Mountaineer & Aviator 8 05-22-2016 11:35 PM
2008 6.8L F250 Crew Cab Keyless entry onelowhog 1999 to 2016 Super Duty 0 02-20-2016 01:11 PM
Tags
2000, code, codefor, door, entry, excursion, factory, ford, keyless, keypad, lock, master, reset, set, unlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
