Keyless entry code (instructions and string)
#31
It was easy to find the code on the module under the dash. Lay your head by the gas peddle, look up behind the radio, see black box with at least 3 (about 20 pin) wire plugs going into it, get a mirror up in there so you can see the TOP SIDE of the black box and write down the 5 digit code you see in block letters. The code is reversed in the mirror so try it both ways. lol
#32
our is a old piece of dinosour! 00 im told they aint got no codes under there.
#34
Did this to my 01, just kept plugging away till i found it got lucky and the first one was the factory reset....took about 15 min.
ive heard on some of the newer ones it locks you out after a few tries so you have to use the key once and then keep pluggin away.....
great trick though until someone tries to steal your truck this way.
#35
Thanks.
#36
Read post number 3...
#37
Which is why you NEED put an alarm on your rig (or put your {Insert bad a$$ dog here} inside)...this "feature" will let a thief right in to steal your stuff.
Who am I kidding...if they want your stuff, they will get it...the alarm just gives you time to get your shotgun.
#38
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
Does this work on a 2000 Model? I have tried this but never heard the horn or had it lock/unlock.
I was lucky the day I went to the dealer and he gave my master code at no charge! I guess the smaller town dealers are a little more willing to get my business than a bigger area dealer!
#39
#41
#43
As usual with FTE...Awesome info in these forums! I used the info in this thread to find the master Keypad code on my new-to-me 2004 Excursion. After 20 minutes of working my way through the number list, and having to wait for the keypad to reset after xx attempts (the Key On-Key Off trick did not work for me) I tried method number 2....use a flashlight and a mirror.
Happy Dance
Happy Dance
#44
