E-150 front and rear track
Old 06-23-2011, 06:37 PM
ydaveitsu's Avatar
ydaveitsu
ydaveitsu is offline
Well, here's another question? I never knew there was such a difference between the front and rear track on these Ford vans. But, come to find out there is a 2-1/2" difference between the front and rear. On the back roads of Maine, the wheels like to follow the ruts. The rear is back and forth like your on snow or ice. Which is the best way to go here, different off-set wheels or wheel spacers? I'm thinking of wheel spacers because of the cost of buying wheels with different off-sets and also I just refinished my Ford OEM wheels that came on the van. I have heard bad things about the spacers with studs breaking and causing the axle bearings to burn up
Need some input as to what you guys think. Thanks !!
Old 06-25-2011, 07:11 AM
SilverE350's Avatar
SilverE350
SilverE350 is offline
I don't understand why people are so adamant that the front and rear tracks need to be the same width. It has obviously been engineered that way for a reason. Many if not all cars are built this way, have you ever looked at a Chevy pickup? Huge difference.
The reason your van feels so loose in the rear has nothing to do with the different track widths. It's all in the tires and suspension.
Some aftermarket wheels, spacers the convert from hub centered to stud centered, that's deficient engineering.
Old 06-25-2011, 07:47 AM
Killer RC's Avatar
Killer RC
Killer RC is offline
Actually, wheels would be cheaper than spacers. Good spacers are about $350 a pair. My aftermarket wheels are $112 each.
Old 07-12-2011, 08:31 PM
76Chateau's Avatar
76Chateau
76Chateau is offline
8 Lug 6.5" To 8 x 6.5" Wheel Adapters / Spacers 2" | eBay
This is the set that I bought back in December, have had no problems with them.
Old 07-12-2011, 09:05 PM
Killer RC's Avatar
Killer RC
Got pics of your van? How close is the tire to the fender now?
Old 07-12-2011, 09:18 PM
76Chateau's Avatar
76Chateau
I'll get some pics. tomorrow and post then
Old 07-13-2011, 04:18 PM
76Chateau's Avatar
76Chateau
Here are some pics. with the spacers on the rear.
<a href="http://s49.photobucket.com/albums/f289/soldirscreed/?action=view&amp;current=DSCF4915.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f289/soldirscreed/DSCF4915.jpg" border="0" alt="Photobucket"></a>
<a href="http://s49.photobucket.com/albums/f289/soldirscreed/?action=view&amp;current=DSCF4918.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f289/soldirscreed/DSCF4918.jpg" border="0" alt="Photobucket"></a>
<a href="http://s49.photobucket.com/albums/f289/soldirscreed/?action=view&amp;current=DSCF4913.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f289/soldirscreed/DSCF4913.jpg" border="0" alt="Photobucket"></a>
<a href="http://s49.photobucket.com/albums/f289/soldirscreed/?action=view&amp;current=DSCF4914.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f289/soldirscreed/DSCF4914.jpg" border="0" alt="Photobucket"></a>
Old 07-13-2011, 04:23 PM
SilverE350's Avatar
SilverE350
Those are some seriously chunky tires! I like them. Is it 4x4?
Old 07-13-2011, 04:37 PM
76Chateau's Avatar
76Chateau
No but I still have fun with it. It seems to always get stuck when I stop. But someday I will have me a 4 X 4 van.
Old 07-14-2011, 05:54 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
I'd be interested to know where you got the step tubes!
Old 07-14-2011, 07:28 PM
76Chateau's Avatar
76Chateau
I got them through AutoAnything, but don't see them listed anymore. They are still available from Waag. Part # 24922B
WAAG : Application Guide : Sidetubes
Old 07-23-2011, 10:07 PM
ewired's Avatar
ewired
ewired is offline
What size are the firestone's?
Old 07-24-2011, 05:34 AM
76Chateau's Avatar
76Chateau
LT265/75 R16
Old 10-06-2011, 11:56 PM
E350John's Avatar
E350John
E350John is offline
Enlightened User
You'll hear a lot about turning radius loss with spacers, I would rather have more stability. I went with spacers (adapters) from wheeladapter.com (Fred Goeske, the old drag racer). This guy really knows his stuff and produces the only spacer I will use. Most of his propaganda is about the rollover risk, I just wanted a more stable van in the corners.
I used his 2" adapters which are machined steel with hardened steel studs. I used red thread locker to bolt the adapters on, along with the lug nuts provided in the kit. I didn't use any thread locker on the wheel lugs. I pulled the wheels and checked the torque at 100 miles and they hadn't budged.
The van now handles great in the corners, turns really level (flat), no lean! Feels a lot better to me!
Here's a few pics:
Old 10-07-2011, 08:52 AM
Motomedic's Avatar
Motomedic
Motomedic is offline
Hey 76chateau-slider or barn doors? I haven't checked the clearance to my slider but I'd like to space things out as well.
Quick Reply: E-150 front and rear track
