ULSD or LSD?
The news may not be good. Sorry. If the truck you imported was built for a country where ULSD is required, you will do damage to it. Below are the sections from the Ford Diesel supplements for both ULSD and higher level sulfur content engines.
FUEL REQUIREMENTS - CHOOSING THE RIGHT FUEL: VEHICLES
OPERATED WHERE ULTRA LOW SULFUR DIESEL FUEL IS
REQUIRED (UNITED STATES/CANADA/PUERTO RICO/U.S. VIRGIN
ISLANDS AND OTHER LOCALES)
Use only Ultra Low Sulfur (15 ppm Sulfur Maximum) number 1-D
or 2-D diesel fuel (also known as ULSD) in your 6.7L diesel
engine. The engine and exhaust system were designed to only use this
fuel. Look for the ULTRA-LOW SULFUR HIGHWAY DIESEL FUEL
(15 ppm Sulfur Maximum) label on fuel pumps when purchasing your
fuel.
Using low sulfur diesel fuel (16-500 ppm) or high sulfur diesel
fuel (greater than 500 ppm) in a diesel engine designed to use
only Ultra Low Sulfur Diesel fuel will cause certain emission
components to malfunction which may also cause the service
engine soon light to illuminate indicating an emissionsrelated
concern.
Diesel fuel is adjusted seasonally for cold temperature. For best results
at temperatures below 20°F (-7°C), it is recommended to use a diesel
fuel which has been seasonally adjusted for the ambient conditions. See
Cold weather operation in the Driving chapter of this supplement.
FUEL REQUIREMENTS - CHOOSING THE RIGHT FUEL: VEHICLES OPERATED WHERE ULTRA LOW SULFUR DIESEL FUEL IS NOT REQUIRED
For the engine to operate reliably on low sulfur or high sulfur diesel fuel,
the engine must be a high sulfur configured engine or a ULSD
fuel-configured engine that has been retrofitted for high sulfur diesel fuel
use.
Use only a diesel engine that has been configured for use with
high sulfur diesel fuel in markets with diesel fuel that has sulfur
content greater than 15 ppm. Using low sulfur diesel fuel (16–500
ppm) or high sulfur diesel fuel (greater than 500 ppm) in a diesel
engine designed to use only Ultra Low Sulfur Diesel fuel may
result in damage to engine emission control devices and the
aftertreatment system, potentially rendering the vehicle
inoperable. Engine damage from using the improper type of fuel
is not covered under your warranty.
Vehicles with engines configured for use with high sulfur diesel fuel will
only be made available for sale in countries where ULSD fuel is generally
not available or mandated by the government. Vehicles originally sold in
a ULSD fuel market that are subsequently exported to non-ULSD fuel
markets will need to be retrofitted (at the customer’s expense) in order
to be reliably operated on non-ULSD fuel.
fuel.
concern.
use.
Thank you for the response. It is highly appreciated.
Quoted: "Vehicles originally sold in
to be reliably operated on non-ULSD fuel."
What type of retrofit are we looking at? A different fuel management system? Different lubricant?
Here is some more information on the subject per the 2011 SD order form which can be found via this link:
ProFleetSales - 2011 SUPER DUTY® PICK-UP (F-250 / F-350 / F-450)
You may need to look into aftermarket support.
Page 21
High Sulfur Diesel Fuel Usage
Vehicles for intended usage with diesel fuel sulfur content
greater than 15ppm require Euro II (>500ppm sulfur) or
Euro III (<500ppm sulfur) packages to avoid engine
functionality issues.
Packages are available through Export Order Guide with
the appropriate US EPA exemption or verifiable export
usage.
NOTE: Post build modification kits are not available.
Vehicles must be ordered correctly for the market that they
are to be sold and operated in.
NOTE: JP8 fuel is NOT supported with these package
usage.
rdbaja - You can use ULSD, even the sticker on the pump says it is OK too. Plenty of people around me here run ULSD in their 7.3L and 6.0L Ford Diesel that were made prior to ULSD being released. You might want to consider a fuel additives for extra lubricity. Some people say they are snake oil, others swear by them.
BTW - I am jealous that you have a diesel ranger... What kind of highway mileage do you get with it, if you mind me asking?
For the OP - If you have a DPF and SCR, you are going to have to use an aftermarket company to get rid of the EGR, DPF, and SCR system. Requires a delete plate, replacement delete pipe, and a programmer. I don't see a way around it with 50 PPM fuel. Ford used to support retro-fitting if the truck was ordered for one market and then later shipped into another, but probably because of our EPA they don't anymore.
So what do guys with new 6.7s do for fuel when they go into Mexico from the US? Is ULSD available at all down there? At some time I'd like to take a trip down there, but no ULSD availability would mean I wouldn't get very far.
My personal opinion, I won't be going to Mexico with my 6.7 without it being deleted... I have no plans to delete and therefore, no plan to drive my truck to Mexico. Even if someone verified that there are places you could potentially get it.... I wouldn't trust it. Just my .02.
You might be able to figure out a way to get a vehicle from Mexico into the US, but it won't be able to be legally registered here. Of course as long as your Mexico warranty was transferable to the US you might be OK. Remembering that you will have to keep Mexican plates on it. In reality, there are all kinds of rules and laws to prevent you from doing that though.
Vanquish Auto
1999 to 2016 Super Duty
10-27-2017 02:05 PM
