88 idi no power no fuel milage
changed the fuel filter 3wks ago, my boy noticed some leaks on 2 return lines leaking today although I had them replaced a yr ago. never smokes, exhaust leaks a lil where 3" down pipe turns back under the cab, checked turbo out 3 wks ago while replacing glow plugs, 1988 2 local farmers owned it last one only put 813 miles on it in 2 yrs it never left the farm, I thought it had tripped but brake pedal pad looks good and interior is excelant,all is original as far as I know thanks for any help
Received 3,090 Likes
on
doubt that. I am sure he is trying to make boost. If the fuel hasnt been turned up it wont do as good of a job in the boost dept. More fuel is more heat which is boost. You have to be careful but that is what a good pyro is for. I would be a few bucks he is loosing boost somewhere or the turbo is shot. more likely that the seal is shot but hard to tell. Any way we can get some good pics of this thing???
Check the fuel lift pump, i know my truck really woke up after it was replaced.
My truck was a farm truck also, one of the injector lines was replaced by the owner it was about a foot longer than the rest of the injector lines it was homemade and it threw my timing out of whack on the cylinder because it was longer than the rest (that is what the mechanic told me )
but i gained alot of power through replacing that , so look for that looks rigged and listen and anwser the guys above ^^^^ .
Get some pics of it.
IrishCreekFords
1999 to 2016 Super Duty
02-15-2010 02:27 AM
rebel_yell23
1983 - 2012 Ranger & B-Series
20
05-23-2002 08:07 AM
