5.0L timing issue - Page 2 - Ford Truck Enthusiasts Forums
5.0L timing issue
Old 05-23-2014, 04:58 AM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
I have done quite a bit of racing with my mustang, both with E7's and trick flow and have had them on the dyno. It doesn't matter to the 'combustion chamber' what your cam is timed at but does matter when you get spark. The TFs are much more effeicient and require less timing and with the factory EEC IV mine always made best power at 14* advance
Old 05-23-2014, 04:04 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Quote:
Originally Posted by Beanscoot View Post
As for the keyway being in the wrong place, that brings up a side issue. It would have been nice if Ford machined the keyway so it is at top center when #1 piston is at TDC, but of course such is not the case..
Not sure what you're saying here, but the crank keyway is at #1 TDC. When you align the crank key at 12 o'clock, the #1 piston is at TDC
Old 05-24-2014, 08:30 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Mine seems to pull better upstairs @ 13*. I am still tweaking the tune, but it feels pretty good right now, even in this hot weather. I hope to get it back to the track soon just to see how much it helped.
Old 05-25-2014, 01:41 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Baddad, what I mean is that looking at the front of a bare crankshaft one will see that the keyway is located about 45 degrees clockwise to the first (#1) throw.
Old 05-26-2014, 02:20 AM
Ok, that puts it's location at 12 o'clock, so that the #1 piston is at TDC. Which is as it should be.
Old 05-26-2014, 04:09 AM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
Quote:
I had to replace the water pump on my engine last week, and noticed that the front cover gasket has been leaking for a while. So I've been running on low coolant for I don't know how long, even though the temp gauge showed "normal" temps. Today was the first time that I got the system fully burped after replacing the pump and all the gaskets, and noticed the steady state temp reading was slightly lower than before the fix; it's now right on the first quarter indicator, vs between 1/4 and 1/2 before.
So I took the car out for a really long ride, up some steep grades, accelerating as hard as the engine would go, and magically, heard no detonation. Could I have been overheating the engine for all the time that it was low on coolant, and that was what was causing the detonation I had been experiencing? More driving will tell.
In answer to your question, when it was detonating, it seemed to start at full load as the engine reached 4000 rpm. Since I knew that was bad for the engine, I usually let off at that point, so never found out whether it would continue to do it past 4000 rpm. And the highest grade gas that's readily available around here is 91 octane. I've heard that some stations may still carry 93, but I haven't seen them recently.
Old 05-26-2014, 11:00 AM
Running warmer on the temps will increase the tendency to detonate.
Old 06-01-2014, 12:02 PM
LxMan1's Avatar
Yes, you could have had some hot spots in the heads causing detonation. Mine is hard to burp too sometimes.
Old 06-01-2014, 09:09 PM
A picture is worth a thousand words
I'll try to insert the picture:
Hey, it works!
Note that the #1 journal is straight up (TDC) while the damper key is about 45 degrees clockwise.
Old 06-02-2014, 02:06 PM
When the #1 cylinder is at TDC, that crank throw is canted counter clockwise about 45* and the keyway it straight up at 12 o'clock.
Old 06-02-2014, 03:01 PM
LxMan1's Avatar
That is correct.
95 7.5L, No CEL, No Codes, Feels Sluggish kfcoltn 1987 - 1996 F150 & Larger F-Series Trucks 2 08-29-2016 11:34 AM
Gonna set it on fire in the driveway...... cobrafromhale 1987 - 1996 F150 & Larger F-Series Trucks 59 08-17-2016 04:52 PM
Absolutely can not find timing marks on flywheel efrntzl 1968-2013 Full Size Vans 5 09-19-2015 10:12 PM
Van won't run @ 10*BTDC initial timing BrianLaverty 1968-2013 Full Size Vans 10 07-19-2013 07:46 PM
2000 2.5L Detonation Issues Briar Ranger & B-Series 5 04-15-2008 11:15 AM
Tags
1997, 2000, 50, 50l, 88, cam, crank, engine, ford, ford50ltiming, ideal, liter, mark, marks, marksmarks, tdc, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
