single gas tank to dual?
The tank, the sending unit, the fuel selector valve, and basicly the whole system is different on your truck compared to his.
A: You have a six port selector valve, he would only have a three port with no return lines.
B: No in-tank fuel pumps, his is mechanical on the engine.
C: The tank opening where you put the sending unit in your tank is larger than his because yours takes a sending unit with in-tank pumps, and his is just a regular old fashioned sending unit.
D: Even your fuel selector switch in the dash is different than what he would need.
The only thing he could use from your truck is the filler neck.
I want to replace my stock 1980 interior heating/cooling module thing with the stock module from the 1985 (b/c the 1985 includes the fuel tank switch) -
Will the easiest thing be to:
A) trace and pull all of the wiring attached to the 1985 fuel switch module so that I can use it in the 1980...(From memory, the '85 the fuel tank switch had maybe 10 wires running into it.. I don't yet know where all these wires run!)
B) get an electric fuel pump to update the 1980 side tank
C) Do I have to replace the 1980 circuit board on the back of the gauge cluster with the one from the 1985 donor?
I have a similar situation - 1980 19Gal side tank w. mech pump - My interior/dash is completely taken apart right now. I have a new pickup bed (dual tank) & want to add the rear tank. I have a 1985 (dual tank) donor truck. This is what I'm working with:
iwals
02-19-2016 08:27 PM
PRIMERED79 SHORT BED
12-25-2015 07:27 PM
