1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front Brakes Locking Up
Old 06-22-2011, 07:19 PM
msgtg's Avatar
msgtg
msgtg is offline
Just replaced the front pads on my 03 F250. Put everything back together without any problems...until I test drove it. The fronts are dragging really bad...I've got to get on it just to get it to move.
It's like the e brake is on...but it's not. Any ideas guys?
Right now Plan A is to have it towed to a buddy's shop in the AM (I'm not comfortable driving it as is the 8 miles to his shop) and having his crew look it over.
Joe
Old 06-23-2011, 09:35 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Did you take the slide pins out and grease them? If they are not sliding, they could hold the pads against the rotors.
Old 06-23-2011, 09:40 AM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
I'd look at those slide pins as well.
But if they are good then the calipers may have an issue.
Take a look at the old pads. Were they evenly worn from side to side?
Old 06-23-2011, 01:37 PM
BendixAnswerMan's Avatar
BendixAnswerMan
BendixAnswerMan is offline
I agree with the previous two posts.
If the brakes are dragging a good inspection is in order. If the truck is off the ground the wheels should rotate freely. If you feel the drag you can slightly loosen the caliper bleeder. If a small amount of fluid comes out and it releases, then it is a restriction in the hydraulic system keeping the brakes applied. If the caliper continues to drag, then it is a mechanical drag that could be cause by the slider pins, bores, or a binding caliper piston.
The caliper pins on these trucks have a tendency to freeze or become hard to slide due to rust, corrosion, or old dry lube in the bores. When the pins are removed they should not be pitted or worn. The bores can be cleaned with a small round wire brush and brake clean, and then wiped out dry.
If you are performing a brake job be sure all areas that support movement are cleaned thoroughly. Lightly lube the pins and these areas using a good quality hi-temp synthetic brake lubricant to keep it from binding up again.
Old 06-23-2011, 02:10 PM
msgtg's Avatar
msgtg
msgtg is offline
Yup, you peeps were right.
The slide pins were frozen in the brackets. He replaced the brackets and treated the new pins with anti-seize...problem resolved.
That'll teach me to pay attention to ALL of the moving parts!
Thanks Dudes...Ya'll get a free trip to Joe's beer fridge and if ya stop by on a weekend, we'll throw an extra piece of beef on the grill for ya!
Joe
MadMatt65
1978 - 1996 Big Bronco
04-02-2017 04:40 PM
slack_master
10-26-2016 11:29 AM
tortoise_486
1983 - 2012 Ranger & B-Series
01-31-2005 08:20 AM
BobKoos
16
01-05-2004 04:30 PM
kwilson
09-19-2002 11:33 AM
Quick Reply: Front Brakes Locking Up
