99 Ranger difficult to engage in park
Old 06-22-2011, 06:35 PM
Joejoecat's Avatar
Joejoecat
Joejoecat is offline
I have a 99 Ranger 4.0L Auto 4WD Ext Cab with 125k .Lately I have to move the shifter to the extreme left to get it to engage in Park. It goes into Park easily but will not engage unless it is to the extreme left .Symptoms are it won't start and will roll in the Park position if not to the far left. My fear is that it will get worse and won't engage at all. Thanks.
Old 06-22-2011, 07:52 PM
Rackster's Avatar
Rackster
Rackster is offline
Selector misaligned
JoeJoe,
I believe if you do an Advanced Search here on 'gear selector' or 'transmission selector', you'll find a bunch of hits here regarding similar issues. I have a situation now that my gear selector is spongey feeling and sometimes difficult to engage Drive or Reverse. I sometimes have to move it about to get it to engage the right position. The Haynes manual I have explains how to correct the issue you have; about $24 at Advance Auto. I've read other threads that suggest picking up the OEM service manual; finer detail and more specific I think. Of course, more money but may be worth it in the long run.
Good luck on your issue! I've been living with my issue for a while now, but I'll need to pull of the covers of the steering column to check the spring and lube the moving parts. Hopefully that'll do.
Kevin
swampfire79
01-25-2016 12:16 AM
bronco-jak
1978 - 1996 Big Bronco
12-18-2010 05:51 PM
scott98xlt
1997 - 2003 F150
12-01-2008 04:14 PM
rywegh
05-21-2008 12:32 PM
Crid
10-22-2004 08:18 PM
Quick Reply: 99 Ranger difficult to engage in park
