Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-22-2011, 05:34 PM
BRay09's Avatar
BRay09 BRay09 is offline
Garage is empty, add now
BRay09 is gaining momentum as a positive member of FTE.
95 F150 hard shifting and erratic speedo
When i took the truck for a drive, it was shifing funny. Floor it and it revs high and slowly picks up speed. It acts like it doesnt know what gear to be in. The speedo is also jumping around and will not tell me the speed i am traveling. The motor is the I6 with the E4OD behind it.
I ran the codes and got a 452 in the CM. This states
Computer detected an error in the VSS or PSOM signal during the last 80 warm-up cycles.
The guy said that he replaced the VSS in the dif. I do not know what or where the PSOM is or if it is the same as the VSS.
Could that be my whole problem here?
__________________
Guzzy
1989 F250 Custom
351W with Crane 444232 Cam, 1.7RR in GT40 heads, summit shorties (waiting on Pacesetter LTs)
Isn't the fastest thing, but we will pull your house down
  #2 (permalink)
Old 06-22-2011, 06:37 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 is gaining momentum as a positive member of FTE.Eddiec1564 is gaining momentum as a positive member of FTE.
The PSOM is the speedometer itself. It reads the VSS (vehicle speed sensor) which is located on the top of the rear axle. As the speedometer(PSOM) reads the VSS it processes the VSS and resends the speed info to the ECU(engine control unit) which controls how the engine/transmission operates. Since the speedo it bouncing around I think you should check the VSS in the rear axle. Even if someone said they replaced it, there could be bad wireing connections or the sensor impropely installed.
If the VSS checks ok, you may have to check the tone ring inside the axle it may be dammaged. If that is Ok, then the PSOM could be the problem and best way to check it out is find one in a junkyard and swap it in.
__________________
95 E350 460/E4od 4.10 The Bus
89 F250 2x4 302/AOD 3.55
84 F250 4x4 300/np435 3.55 The BLUE MULE
85 Plymouth Caravelle
73 Buick LeSabre
  #3 (permalink)
Old 06-22-2011, 08:48 PM
BRay09's Avatar
Would one out of a 94 f250 work with this 95 f150?
  #4 (permalink)
Old 06-23-2011, 07:06 PM
The PSOM itself should be a direct swap. As for the whole cluster, I am not sure without relooking up the info again
__________________
73 Buick LeSabre
  #5 (permalink)
Old 06-23-2011, 10:46 PM
jimbo285's Avatar
jimbo285 jimbo285 is offline
1994 Ford Bronco
My Garage
jimbo285 is starting off with a positive reputation.
My 96 F250 with 7.5 had jumpy speedometer needle, late shifting and extremely hard shift, died when shifting into reverse or drive...changed instrument cluster (Speedo, tach and all gauges) fixed everything.
__________________
94 Bronco XL 5.0 (gutless) 31" BFGs
96 F250 XLT 460 4" rancho 33" BFGs
  #6 (permalink)
Old 06-24-2011, 08:47 AM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
The PSOM:
Click the image to open in full size.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #7 (permalink)
Old 06-24-2011, 12:25 PM
BRay09's Avatar
Can i just swap that from the 94 F250 to the 95 F150 from the back of the cluster, or is it easier to just swap clusters?
__________________
Guzzy
1989 F250 Custom
  #8 (permalink)
Old 06-24-2011, 12:34 PM
subford's Avatar
You have to take the speedometer head out and then the PSOM unplugs from the speedometer after you take the PSOM screws out. It comes out the front.
Swapping clusters is easier as you do not have to take the cluster apart.
__________________
subford@gmail.com
  #9 (permalink)
Old 06-24-2011, 02:54 PM
BRay09's Avatar
How easy is the cluster to take out? I have till sunday to get this truck done. Let's hope it isnt too difficult.
Still need to swap gear boxes. Of course the 150 and the 250 use different pitman arms... These are a pain to get off!
__________________
Guzzy
1989 F250 Custom
  #10 (permalink)
Old 06-24-2011, 03:46 PM
tony. b tony. b is offline
tony. b is starting off with a positive reputation.
It's not hard. I just did mine today had it out in about 20 mins. Pop off the two trim pieces under them are two torx screws then you can get the dash bezel out, there is also a couple clips that hold it in so don't just yank it then unplug tank selector switch so you can get the bezel out of the way. Then take off the panel underneath the wheel two screws and a few clips. I took the plastic from around the Colum off I'm not sure I had to but the cluster didn't seem to want to come out with it on. It's four screws on the under side then take out the ignition cylinder and the plastic will be out of the way. Then shook the little cable for the shift indicator. Then four screws on the cluster and you can pull it out enough to unplug the three plugs behind it and it will come out. Sounds like a lot ,but its really not like I said had mine out in 20minutes.
  #11 (permalink)
Old 06-24-2011, 05:31 PM
Meant to say unhook the cable not shook.
  #12 (permalink)
Old 06-24-2011, 06:31 PM
BRay09's Avatar
Well i swapped clusters and its still doing the same thing... Is there another VSS in the trans? parts store guy said there is two listings for this truck. Ill be checking the one out in the diff in the mean time
__________________
Guzzy
1989 F250 Custom
  #13 (permalink)
Old 06-24-2011, 07:17 PM
From what I've learned on this forum there is only one and its on the rear diff. My 94 only has the one on the diff.
  #14 (permalink)
Old 06-24-2011, 07:19 PM
subford's Avatar
Yes the 95 only has the one VSS on the rear end.
__________________
subford@gmail.com
  #15 (permalink)
Old 06-24-2011, 07:23 PM
subford's Avatar
All so try unplugging the Speed Control Module as that can give that codes also along with hard shifting just like the VSS or PSOM. I see now you said the speedometer was jumping so the speed control module would not be it.
You might try unplugging the RABS Module also as it can give this code also.
Or just unplug them both and see what happens.
__________________
subford@gmail.com
Tags
1995, bouncing, eratic, f150, f250, ford, gear, hard, jumping, passing, rough, shift, shifting, speedometer, transmission, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
