6.2L V8 Discuss the 6.2L V8
Differance between the 6.4's brakes and the 6.2's?
Old 07-05-2011, 07:57 AM
nycsteve's Avatar
nycsteve
nycsteve is offline
Is there a differance between the 2? It seems the 2008 6.4 had more stopping power than my 6.2. Did they beef up the brakes in the diesel vs the gasser 6.2? Did I miss an option for better brakes when ordering?
Old 07-06-2011, 12:01 AM
RadRick's Avatar
RadRick
RadRick is offline
The brakes themselves are probably the same. The difference is that since gas engines generate intake manifold vacuum they generally come with vacuum boost brakes. Diesels have no vacuum to speak of, so the use hydroboost brakes with the power steering pump supplying the pressure. Hydroboost brakes have the potential for much more braking power. On the 6.7 Diesels there is an engine driven vacuum pump, and on some models this is used to run vacuum boost brakes, while other models use hydroboost. I'm not sure if all 6.4's are hydroboost or not. In the past the only way to get hydroboost brakes on a gas engine was to order a dually, but I think that went away with the 2011's.
Old 07-06-2011, 09:05 AM
Super08's Avatar
Super08
Super08 is offline
Starting in MY2012 the Diesel SRW trucks with the 6.7 will have vacuum boost brakes as well.
Shernius
1999 to 2016 Super Duty
26
08-11-2015 09:55 AM
sundance1
6.2L V8
13
11-20-2013 10:20 PM
old broke prospector
07-10-2013 10:53 PM
nycsteve
6.2L V8
33
02-10-2011 06:47 PM
5 Star Tuning
6.2L V8
10-12-2010 07:01 PM
Quick Reply: Differance between the 6.4's brakes and the 6.2's?
