a little help would be awesome
06-22-2011, 03:48 PM
on
Ok Im new to fords all my buddys have fords and are telling me to switch over so I . Switched over from chevy. I am buying a f150 xlt, 302 fuel injected 2wd , I took it for a test drive, I noticed a clunking like a clunk clunk ( two of them) everytime the truck would upshift or downshift into the other gear under normal driving, , The guy im buying it from said the u joints were on there way out. Easy fix. But would that cause a clunking noise It sounds like right at the transmission, You can hear it while you drive. I dont want to buy a truck wtha bad transmision!! Would bad u joints cause this?? Any help would be appreciated. I didnt notice any lag in the hard downshift, It was instant power, Any ideas.
06-22-2011, 04:15 PM
If it is an "easy fix" ask the seller to replace the u-joints before you agree to purchase the truck. Drivetrain noises can be an indication of some very expensive repairs. Whether it's a Chevy or a Ford use some common sense before purchasing any used vehicle.
06-22-2011, 04:30 PM
^^What he said is the best answer. But you could always crawl under it and give the driveline a few twists and shakes to see if there is any play in the u-joints.
06-22-2011, 05:00 PM
yea crawl all over the truck and check it out, if your not sure and know a good friend who works on cars or is a mechanic bring them along and have them check it over thoroughly for any issues
remember use common sense when buying any vehicle
06-22-2011, 06:27 PM
on
Do as the others suggest and check it out closely or have someone more knowledgable do it but I can tell you that mine did exactly what you describe and it was caused by bad U-joints.
06-22-2011, 07:10 PM
on
Yea I will I smelt the atf it was Nice and red. Not burnt smelling. The Guy I'm buyin g from is an honest trustworthy Guy. That I've seen everyday For 4 years.which always helps. I look it over even closer. Thanks guys. The truck still shifts really smooth.
holman794
03-05-2012 05:47 PM
corbin9191
11-08-2011 09:15 AM
Bolder1235
1997-2006 Expedition & Navigator
07-04-2011 11:06 AM
birdseyelogger
Escape & Escape Hybrid
03-31-2011 08:10 AM
powersmoked
1983 - 2012 Ranger & B-Series
06-20-2010 10:36 AM
