Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Today's Posts VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-22-2011, 02:52 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is online now
1968 Ford F-100
MIKES 68 F100 is gaining momentum as a positive member of FTE.
Question SMOG TUBE HEADS ? PLUG THEM ?
My 67 tbird 390 has the smog tubes on the exhaust port , i plan on plugging them but my question is do i remove the tube that's in the exhaust port ? it's like 1/4 diameter and sits dead center in port .
since i am blocking it with the threaded plug i can just hack it off right ?
  #2 (permalink)
Old 06-22-2011, 04:35 PM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
Garage is empty, add now
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
The tubes can be removed. They drop in from the top and get seated from the tube nut and ferrules when installed. You should be able to get them out without much trouble.
  #3 (permalink)
Old 06-22-2011, 04:45 PM
1968 Ford F-100
thanks , they must be crusted in i'll try some wd40 and wiggling
  #4 (permalink)
Old 06-23-2011, 09:43 PM
1968 Ford F-100
anyone know where to get the plugs ?
7/16 fine thread i think
here's some pics of the drivers head torn down
looks pretty low mileage to me .
Click the image to open in full size.
  #5 (permalink)
Old 06-24-2011, 06:36 AM
FFR428's Avatar
Needsmorecoffee.
I think Ford still sells them. Numbers Dummy Bill might know or have a source. If not DSC or Mansfield Mustang sell them.
DSC Motorsport Ford Racing Parts
Welcome to Mansfield Restoration Parts
Those heads have been milled pretty good looks like. Almost no thumbprint left and someone opened up the oil passage slot to get some oil back up to the heads. I'd do a mockup to be sure they fit and lineup ok with your intake before you do anything further. Hopefully they'll be just fine
  #6 (permalink)
Old 06-24-2011, 08:44 AM
1968 Ford F-100
THANKS , i heard ford had them but wanted like $15.00 each
Tags
1966, 360, 460, cylinder, fe, ferrules, ford, head, heads, holes, plugging, pluging, plugs, smog, tube
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
