A/c Blower defaulting to the defrosters - Page 5 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
  #61
Old 06-05-2014, 03:33 PM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Quote:
Originally Posted by JWA View Post
That's the biggest time saving move you can make Pick'r, trust me on that!
Twice I've dismantled a lot of components inside and under the hood looking for that Loch Ness Monster of a never seen part---if I didn't know better I'd swear they just didn't exist!
Its odd it can be so easily and cheaply bypassed so maybe its a non-issue for anyone facing this repair and lucky enough to have found us here on FTE.
I went to the dealership near my house yesterday to buy some other parts & the parts guy gave me a diagram - & said it was mounted on top of the blower plenumn on my year/model. The picture looks like it is there but I went out & hunted for it & no luck. This must be one of the best kept secrets in the trade. Kinda like sending the apprentice for a bucket of steam, Ha - Fandnago I say .
  #62
Old 06-05-2014, 07:31 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
It's under the unit, basically, the stealership vacs out the system, removes the dash, and pulls the entire heat/ac box out of the passenger side to get access to replace it, I heard a $1700 job. So you can either cut through the passenger wheelwell, or relocate the dam thing to a spot where you can get access, inside the van, pull the radio out to get your hand in behind the dash to route the hoses, drill through the firewall to pull in the vac line. This is the result of building a vehicle without leaving room to access parts that may fail in the future, face it, studies show buyers don't keep the vehicles past 5 years anyhow, and second owners are not a concern, they just build it to last for 100,000 miles.
  #63
Old 06-07-2014, 12:04 PM
guitarpicr's Avatar
Quote:
That is crazy -They make work for their dealers one way or the other. Will def. relocate same & make my own vacuum resevoir out of 1-1/2" pvc pipe. I know that will hold up for a while. I'll mount it down there somewhere easy to access. I do hvac work for a living so I have all the tools,but why bother with it when it can & should be relocated. Thanks for the reply. Bill
  #64
Old 06-07-2014, 04:20 PM
maples01's Avatar
They don't think about items like this, it isn't designed to be replaced or reached, as I said, the numbers tell manufactures that buyers don't keep their vehicles, built to last till replaced.
  #65
Old 06-29-2014, 03:39 PM
ChecoHill ChecoHill is offline
ChecoHill is starting off with a positive reputation.
Just like to say thanks a lot to you guys for all this info and research - sorted out my malfunctioning controls on a 2000 E350 with the help of this thread and some bits and pieces I had lying around. It's working really well now - now I can start trying to work out why the AC itself isn't working. One step at a time!
  #66
Old 06-29-2014, 03:51 PM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Glad anything we posted was helpful----that vacuum system can trip up those not familiar with its operation.
As all the doctor shows say: "watch one, do one, teach one.........." so now YOU too can help the next guy stumbling through this mess on our vans!
  #67
Old 06-29-2014, 10:00 PM
maples01's Avatar
Is this leak enough to cause lean codes on both sides and an engine miss, it's leaked for 8 years, before this started?
  #68
Old 06-30-2014, 06:17 AM
JWA's Avatar
JWA JWA is offline
Unless the hose off the manifold is completely snapped apart it shouldn't trip the MIL to indicate "lean bank 1 or 2" nor the rough idle.
  #69
Old 06-30-2014, 06:26 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
When those vacuum chambers go bad just put in an after market one way check valve and route the line to the main feed to the control head. happy, happy, happy
  #70
Old 06-30-2014, 06:33 AM
JWA's Avatar
JWA JWA is offline
Not sure if I've already posted this link to another way to approach this issue: http://www.ford-trucks.com/forums/12...-problems.html
  #71
Old 06-30-2014, 08:13 AM
Phone_girl_NE Phone_girl_NE is offline
Phone_girl_NE is starting off with a positive reputation.
My mechanic added a valve and canister from an older Ford ahead of the old canister. Seems to be working, so far anyway.
  #72
Old 06-30-2014, 10:22 AM
maples01's Avatar
Just hoping my misery is that stupid canister, the miss started after the transmission was rebuilt.
  #73
Old 07-01-2014, 03:47 PM
br54niner br54niner is offline
br54niner is starting off with a positive reputation.
e350 2005
hello I had the same problem with my van I cut a patch out of the inner fender and found the 3inch long piece of vaccum hose going to the vaccum can to the directional valve had just fell off. .35 cents later problem solved. they couldn't have put it in a worse spot.
  #74
Old 07-04-2014, 12:14 PM
jeffnick jeffnick is offline
jeffnick is starting off with a positive reputation.
My '05 E350 had the vacuum problem. I did the bypass.
I took the old vacuum line apart at the windshield connector and put in a new check valve (from autoparts store @ ~$4).
I then jerked out the old vacuum line from the firewall inside the passenger foot area. I left enough at the inside end for connections and cut off the rest. I ran a coat-hanger back into the hole and wiggled/pushed it until I could find it under the hood.
I then attached a piece of fish tank hose (it's all I had at the time) to the coat-hanger and pulled it through from under the hood. I attached the hood end to the check valve.
On the inside end of the new hose I put a "T" for the vacuum tank. I'm not sure what size PVC I used but it tucked up nicely above the plastic housing under the dash using only a cable tie.
Then connect the fish tank hose to the open end of the one I pulled out and we're in business.
This is basically the same fix as mentioned above, except there's no no holes to drill you just use original hole with a new hose.
And DON'T use fish tank hose. If you look at the first pic, you can see it has collapsed from the vacuum. It still works fine but it takes about 10 seconds when the van is started in the morning.
  #75
Old 07-04-2014, 12:39 PM
maples01's Avatar
I have vacuum hose from a wound vac, it's setup for a lot of negative pressure, same inside diameter, but the outside almost looks like fuel line. LoL
So the red hose is running through the loom at the hood, shouldn't be difficult to handle, you go from there to the firewall, why not use the tubing that run through there?
What I've learned from owning a 1999 E450 V10 jyro 1999 to 2016 Super Duty 1 01-27-2017 09:08 PM
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
Easy cheap quick fix for Ford defrost/vent problems auric Cooling, Heating, Ventilation & A/C 14 04-17-2016 11:12 PM
Vacuum leak under dash??? npccpartsman 6.0L Power Stroke Diesel 2 09-27-2015 06:53 AM
Vacuum line to heat/AC unit johnr9q 1968-2013 Full Size Vans 35 06-10-2015 02:32 PM
Tags
2006, 99, ac, blower, box, clean, control, e250, f150, ford, head, heater, hvac, line, located, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
