My 2006 ford f250 turbo diesel wont restart. - Ford Truck Enthusiasts Forums
Old 06-22-2011, 01:41 AM
frustratedowner frustratedowner is offline
frustratedowner is starting off with a positive reputation.
I have a 2006 Ford F250 Turbo Diesel super Duty 4X4, that is giving me issues. It will not show any codes and when I drive it to the store for example and come back out apporximately 10-15 minutes later, the truck will not start. In fact it will take about 20-30 minutes to restart. It turns over and sounds like it is not getting any fuel and wont start.
I am hearing that it might be the ignition module which cost approximately $1500 to fix. I am also hearing it might be the fuel pump, or the oil pump. I am completely frustrated and lost. I have been stranted 6x in the last week and I am getting the run around from dealer shops.
Does anybody have an idea of what this might be and I wonder if anybody has experienced anything like this with their truck.
Thanks
Old 06-22-2011, 02:46 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
Old 06-22-2011, 05:16 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
No-starts can come from many different problems. You need to do some methodical troubleshooting or you will have a HUGE repair cost by just changing parts.
There is a no-start troubleshooting thread in the Tech Folder (second thread down from the top of) that will help you test the more common things.
First - what code reader are you using to check for codes?
Second - what are your maintenance practices - specifically with fuel filters, and oil and filters? What oil are you using and how many miles since the last change? What BRAND of filters are you using?
Third, I am skeptical about the ignition module or the fuel pump being the issue with the behaviour you describe. The oil pump that you are being told about is no doubt the HIGH PRESSURE oil pump (HPOP) and not the low pressure pump (LPOP), but on a 2006 these pumps are pretty reliable. If you crank a lot and ruin your batteries, you can aso damage your Fuel Injection Control Module (FICM). It is an expensive part, so make sure your batteries are healthy. Best way to do this is to charge them up, and then have them INDIVIDUALLY load tested at a good shop (dealership, battery shop, or even an autoparts store).
It sounds like you have a leak in the high pressure oil system. The common leak points in a 2006 model year are
1. Discharge fitting off of the high pressure oil pump (HPOP - called the snap-to-connect (STC) fitting
2. Dummy plugs in the oil rail
3. Stand-pipes in the oil rail
4. Injectors
Again, the no-start thread can help you determine IF you have a leak and WHERE the leak is coming from if you do have a leak.
If you want to be capable of troubleshooting your 6.0L vehicle (now and in the future), you need gauges and a scanner of some sort. The scangaugeII is a good tool.
No matter what scan tool you buy (if you decide to do so), you will need to add a sending unit and a gauge for fuel pressure and exhaust gas temperature. These are important things to watch, and Ford did not give you a way to do so.
This is probably not related to your no-start, but MANY 6.0L engines are operating w/ too low of fuel pressure. This can damage injectors over time. There is an easy fix ... buy and install a stiffer spring (from Ford) for the fuel pressure regulator. This is important for lomg-term reliability IMO.
Please answer the questions from earlier in the post, read up, start troubleshooting, then post back.
We (this forum) have part numbers for most of the things you may be buying and can provide specific help on installing components.
Welcome to FTE.
Edit - for your convenience here are links, but it would be to your benefit to know where the Tech folder is and what is in it!
Tech Folder:
http://www.ford-trucks.com/forums/30...ch-folder.html
No-Start thread:
http://www.ford-trucks.com/forums/87...condition.html
Old 06-22-2011, 07:05 AM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Could be the stc fitting.
Old 07-12-2011, 07:13 PM
HPOP Removal and component replacements
Thank you guys so much
I have found out that of course it is my HPOP and I need to know if you really need to use the OTC 303-755 Quick release coupling disconnect tool? I have read many forums and have not heard anything about this tool. according to Ford it is requried to work on the HPOP? HELP! please
2006 Ford F250 6.0 no crank no start OUTATIME 6.0L Power Stroke Diesel 0 10-24-2016 10:31 AM
Stalled F250 XLT Super duty International 6.0 Andrewhermanson 6.0L Power Stroke Diesel 6 11-09-2015 10:27 AM
97 F150 4.2 intermittent start issue need a little help! Turbo442 1997 - 2003 F150 14 03-25-2015 09:43 PM
2006 Idled, died, and now won't start! T2Load 6.0L Power Stroke Diesel 1 11-03-2011 11:28 PM
My 2006 ford f250 turbo diesel wont restart. global 6.0L Power Stroke Diesel 8 08-27-2011 08:10 PM
Tags
2003, 2006, 2009, deisel, diesel, f250, ford, low, oil, pressure, pump, reasons, start, swap, turbo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
