99 F250 SD V10 Rear Brake Issue HELP!
My left rear brake is once again hung up after replacing the slide pins and greasing them up, everything slid fine with I put it back together. No problems at all for the last month until tonight on my way up the left rear locked up completely at a red light, i drug is for a couple feet and it freed up, not the brake is hanging just enough that after going a little ways smoke starts rolling off the brakes.
Why is it doing thing all the time even after replacing everything imaginable?!
This happened on my front passenger top slide pin. After I got my truck, i did a brake job and discovered that the top pin was seized. Had to hear up the bracket to get it out. I tore up the rubber boot in the process lol. Still can't find a new rubber boot lol. Anyways I cleaned uo the pin and inside hole on The brake bracket and greased everything real good. Once a year I just go in and re grease everything and it seems to be working.
IDIDieselJohn
20
04-19-2011 11:15 AM
IDIDieselJohn
44
04-05-2011 09:55 PM
