Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 06-21-2011, 09:01 PM
painterman painterman is offline
Garage is empty, add now
painterman is starting off with a positive reputation.
WTB 1987-newer Transmission Crossmember for a C6
I am looking for a C6 crossmember that fits the 1987 and up F150 trucks. I dont know if the 80-86 are the same. I also dont know if the OD Auto's are the same as the C6 crossmembers. Thanks, Frank
  #2 (permalink)
Old 06-21-2011, 10:26 PM
duck fan's Avatar
duck fan duck fan is offline
RIP Robin
2000 Ford Excursion
duck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud ofduck fan has much to be proud of
I am pulling the C6 out of my 89 F250 in a couple weeks to swap in a ZF5. I already have a crossmember for the ZF5. If you can wait, I'll have one for you.
__________________
Peter - NHRDA# 5078 - Member of the 200K+ club
2000 Excursion 7.3 - Casserly Stage 1 SS, 6637 w/ Pete's cover, van turbo, ceramic coated exhaust manifolds, IH up-pipes, and exhaust housing, RDP Billet Compressor Wheel, Live Tuned by DP tuner, Warn hubs, gauges, 6.0 IC, MBRP 4" turbo back, Frx, RDP AIH delete, RDP OCR, RDP IC boots, RDP CCV kit, John Wood Trans, Melling LPOP, T500 , Red Head Steering Box, RDP Billet Plenums, 5" lift, B-code springs. and RAS.
  #3 (permalink)
Old 06-22-2011, 03:40 PM
That would work fine. Thank you! I dont need the 2 supports that go to the upper part of the frame. just the part that runs the full length and the tranny hooks to. Mine were a real pain to unbolt because of rust.
mine had a mazda OD 5 speed. its 2 wheel drive. the clutch was bad and i really didnt like all the shifting so i put a c6 in it. It was an easy switch. That mount is wrong for the c6 though. Ive got an angle iron hooked up temporarily but I am not driving it much.
Is there anything you need for your switch? Thanks again! frank
  #4 (permalink)
Old 06-22-2011, 03:49 PM
duck fan's Avatar
RIP Robin
2000 Ford Excursion
I don't need anything I can think of. Where are you located?
__________________
  #5 (permalink)
Old 06-22-2011, 05:16 PM
Minnesota. I'm going to try to send a private message to you. Frank
  #6 (permalink)
Old 07-21-2011, 07:01 PM
Got one! Thank you Duck fan and FTE!
Tags
2000, 89, c6, crossmember, crossmembers, f150, f250, ford, spd, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
