died while driving now won't start - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-21-2011, 07:06 PM
dr_snow dr_snow is offline
dr_snow is starting off with a positive reputation.
I'll start by letting you all know I"m an idiot when it comes to these trucks.
It is a 99 ford f250 7.3. It died while driving and I got it towed home. I haven't been good about maintaining certain things so I put in a new fuel filter. I let the key cycle a few times to prime it and tried to start it. Nothing, it just cranks. I opened the fuel filter and it was dry. I poured some fuel in it up to the threads and tried again. It seems to want to start but nothing. Do I need to bleed the system? If I do, how do I do that. Pics would be great. I'm in Reno if anyone is close. Thanks.
Reiner
Old 06-21-2011, 09:16 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
How did it die? Spit and sputter or like someone turned the key off? For future reference, ask these types of questions down in the 99 - 03 7.3 diesel section.
The way to purge the system is to turn the key on (not start) and count to 20. Turn the key off and repeat the process 3 times. After you do that, turn the key on, and within 20 seconds, open the fuel bowl drain valve. If you're not getting a strong stream of pressurized fuel squirting out of the drain tube, you need to determine why the fuel pump is not pumping fuel.
Does your WTS (Wait To Start) light come on and go off after a few seconds like normal?
Old 06-21-2011, 09:23 PM
It spit and sputtered.
I don't know where the fuel bowl drain valve is.
The WTS (Wait To Start) light comes on as normal.
AE in Nevada koski19 1999 - 2003 7.3L Power Stroke Diesel 25 02-13-2013 03:09 PM
03 F350 6.0 No crank alp41104 6.0L Power Stroke Diesel 13 09-03-2011 07:34 PM
died while driving now won't start dr_snow 1999 - 2003 7.3L Power Stroke Diesel 27 06-24-2011 10:28 PM
76 E250 w/460 vapor lock 76Econoline 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-10-2009 07:02 PM
Hard starting after sitting a day! fastturn 1999 - 2003 7.3L Power Stroke Diesel 7 10-23-2004 09:49 AM
Tags
1997, 1999, 2008, 302, 351w, bronco, died, driving, expedition, explorer, ford, motor, pickup, quit, start, stopped, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
