1994 F350 7.3 glow plugs - Ford Truck Enthusiasts Forums
Old 06-21-2011, 04:32 PM
neilj neilj is offline
neilj is starting off with a positive reputation.
1994 F350 7.3, the issue is the glow plug relay, have replaced once and daughter's mechanic says its bad again. Mechanic says that instead of replaceing the relay again, he can bypass the relay and wire the glow plugs to a button she would have to hold. I don't think this is a bad thing, its pretty much the way things used to be in the past, but with the system on her 1994 will this cause more problems?
Old 06-21-2011, 06:01 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Many guys on here have done that, I prefer getting the current system in proper order.
Old 06-21-2011, 07:03 PM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994F2507.3L is gaining momentum as a positive member of FTE.1994F2507.3L is gaining momentum as a positive member of FTE.
the glow plug system on a 1994 IDI has a controller/relay in one. you can replace the whole thing. you can replace just the relay but usually if one is bad the other is too. the controller piece tells the plugs how long to stay on.
List: Search for 'glow plug controller' | O'Reilly Auto Parts
then you have the plugs themselves. you need to make sure they are motorcraft ZD9's
Motorcraft ZD9 - Ignition Glow Plug | O'Reilly Auto Parts
the only other thing could be power delivery issues which even a manual switch couldn't prevent that you could end up frying plugs..... i suggest getting the stock system in working order.... i love just being able to click the key forward and having no extra buttons to push but thats just me
Old 06-21-2011, 08:28 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
If you should decide to go with a push button, check out these:
www.AccurateDiesel.com - Glow Plugs, Controllers, and Glow Plug Kits
Just want you to have all the information you need to make an informed decision.
Old 06-21-2011, 08:36 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
As stated above make sure that they are motorcraft/beru ZD9's. If you do a search on this site you find many horror stories from guys that used other type plugs. It could mean pulling the heads because of broken off plug tips.
Old 06-21-2011, 10:41 PM
Quote:
While you do your search, make sure to verify exactly what they were using. The only GP that will work with the stock system is the BERU. As I stated, if you go to a push button, look into the other GPs since you can't fat finger them and burn them out. The BERUs have their limits as to how long you can hold them on. The horror storys mentioned involve GPs that are cataloged to fit our engines and they can cause problems.
PS. Actually, if you need to replace the controller, I would strongly suggest using the one from Accurate Diesel. That way, if the controller screws up, you won't burn out your GPs.
Old 06-22-2011, 06:57 AM
ive been running the controller from orielly made by BWD for over a year now and have no issues with it... starts first time every time winter or summer
Glow Plug Relay question Philinoxr 1999 to 2016 Super Duty 2 07-03-2016 03:38 PM
gp relay smoking platinum23 1994.5 - 1997 7.3L Power Stroke Diesel 2 04-03-2016 04:45 PM
94.5 7.3 will not start Meydawg51 1994.5 - 1997 7.3L Power Stroke Diesel 16 10-12-2015 09:01 PM
7.3 IDI Glow Plug Relay CoalRoller7.3 1987 - 1996 F150 & Larger F-Series Trucks 3 10-23-2012 08:22 PM
f 350 glow plug light colokerrie 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-09-2012 04:49 PM
Tags
1994, 73, 94, change, diesel, f350, ford, glow, international, light, liter, plug, plugs, replace, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
