'88 F-150 wont crank HELP!
Old 06-21-2011, 03:18 PM
blueberry188's Avatar
blueberry188
blueberry188 is offline
Cool '88 F-150 wont crank HELP!
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> <!-- / icon and title --> <!-- message --> pulled the motor from my '88 f-150 recently and had it built by a very reliable mechanic..dropped it back in yesterday and got everything hooked up today..went to crank it..turned it over and hit a couple times but wouldnt crank..i dont think its getting fuel, can you get the two fuel lines backwards? any suggestions would be great.. thanks!
Old 06-21-2011, 03:30 PM
andym's Avatar
andym
andym is offline
There's an in and an out for the fuel rail, but it's far more likely that you either left something disconnected, mis-connected, or your base timing is off.
If everything else checks out, loosen the distributor hold-down bolt and move it back and forth while cranking. It should catch somewhere and then you can set the timing with the light. This is, of course, assuming that the engine is at TDC and the rotor is pointing roughly at the #1 post on the distributor cap.
If you do have the fuel lines backwards, you will just have way too much pressure at the injectors because the regulator is not able to do its job. I believe the routing should go: fuel pump, injectors, fuel pressure regulator, return line, but I am not 100% sure. Hopefully someone that knows for sure (subford?) will post.
Old 06-21-2011, 10:47 PM
blueberry188
hey thanks for your advice.. we are going to try a gas rag to the intake tmrw to see if its a fuel problem..will let you know the outcome
xsfg
12-31-2013 01:10 PM
bbf ford
03-20-2013 10:18 PM
Gr8Cook
1997 - 2003 F150
18
12-13-2010 12:53 PM
jimmyb08SD
Florida Chapter
11-09-2010 09:12 PM
hoperox74
Bronco II
01-28-2009 05:36 PM
Quick Reply: '88 F-150 wont crank HELP!
