5.4 Head Replacement - Ford Truck Enthusiasts Forums
Old 06-21-2011, 02:56 PM
kc0rey kc0rey is offline
kc0rey is starting off with a positive reputation.
In an earlier thread, I asked about my 1998 Expedition and it's blown out sparkplug (#3). The hole has been drilled out too big and a Helicoil is not the answer.
I have to replace the head. I found a local salvage yard that has the head for $60.
Any advice on what else I may need?
What do you guys recommend for Gaskets? Will I need to replace the headbolts or can I reuse the ones I have?
Anything to be careful of?
I know I will probably need to replace the Timing Chain Tensioners as there is 171,000 miles on this engine.
Thanks for any help in advance.
Steve
Old 06-21-2011, 03:43 PM
ncon ncon is offline
ncon is starting off with a positive reputation.
I would try a timecert before going through the hassle of a head swap...nothing to loose! I have one im my 5.4 cylinder #3.
For a head swap, I know you'll need the head bolts, as they are torque to yield.
Old 06-21-2011, 03:47 PM
Timesert will not work. I've exhausted all of these possibilities. The hole is 3/4 inch and can not be enlarged with-out getting into the valve seat.
Lots of emails and phone calls to Timesert and another company. The head has to be replaced.
Old 06-26-2011, 06:44 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Fel-pro head gaskets are fine. You need new head bolts!
Summit racing has what you need and they have good customer service.
Most impotent thing is to get the timing set properly, to avoid catastrophic failure !
Which 460 heads for 1986? mitm19 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 10-18-2016 07:49 PM
Help need new heads where to go? fscarrow 1999 - 2003 7.3L Power Stroke Diesel 10 04-21-2015 07:55 PM
FE 360 Head Questions Mister_King FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 01-26-2015 06:32 PM
1999 Ford F250 5.4 Headgasket Oil Leak and PI Heads TBFGhost 1999 to 2016 Super Duty 6 04-18-2011 08:45 PM
Head Removal Tips Wakeboarder141 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 38 06-26-2004 11:45 PM
Tags
06, 1998, 4700, 54, bolts, engine, expedition, ford, head, heads, international, repair, replace, replacement, reuse, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
