2005 F-350 Need Crew Cab Removal Instructions Head Gasket Problem - Ford Truck Enthusiasts Forums
Old 06-21-2011, 01:21 PM
boopsey boopsey is offline
boopsey is starting off with a positive reputation.
Smile 2005 F-350 Need Crew Cab Removal Instructions Head Gasket Problem
We have a 2005 Ford F-350 Dual Custom Cab. There is a blown head gasket and someone said we need to remove the crew cab before we can repair. Is that true? 6.0 Turbo Diesel Would appreciate any info
Old 06-22-2011, 05:54 AM
CPaulsen's Avatar
CPaulsen CPaulsen is online now
CPaulsen is gaining momentum as a positive member of FTE.
People told me this about my V-10 also.....found a shop that does a lot of heads on V-10 in the truck. No pulling the motor or the cab.
Old 06-22-2011, 06:18 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
Old 06-22-2011, 06:21 AM
mrford60's Avatar
mrford60 mrford60 is offline
mrford60 is starting off with a positive reputation.
it is really alot eaiser to do when you remove the cab. but you need a twin post lift or a crane to lift off the cab.
Old 06-22-2011, 07:04 AM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is online now
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
You do NOT need to remove the cab. Thats a waste of time.
Old 06-22-2011, 11:30 AM
beaulauber's Avatar
beaulauber beaulauber is offline
beaulauber is starting off with a positive reputation.
I just did this with access to a 2 post lift. Had never pulled a cab on an f250 so it took awhile to disconnect everything and figuring out what was left to disconnect.
I still think it was worth pulling off. For sure. Now if i didnt have access to a lift, that wouldn't stop me from doing the heads with the cab on.
Old 06-22-2011, 06:14 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
As stated, it is not necessary to remove the cab. It does make the job easier once the cab is removed, but I personally would not go thru all the hassle.
Old 06-22-2011, 06:50 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
with practice one can have a set of heads off and on a bench in about 5 hours time.... cab on.
it dont get much better then that.
Old 06-22-2011, 07:30 PM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
Cheezit,dont you have to remove the a/c box off the firewall to get the passenger head off ? I thought you or one of the other techs said you have to ?
Old 06-22-2011, 07:33 PM
cheezit's Avatar
the box is held on by 5 nuts. just evac and refill the a/c. if you dont have a way to do that you can go to your local shop and ask them to evac it and have them refill it when your done.
Old 06-22-2011, 08:13 PM
jbenford jbenford is offline
jbenford is starting off with a positive reputation.
Quote:
So you don't have to remove any of the hoses?? Or can u just unbolt it and move it out of the way enough to make it work?
Old 06-22-2011, 10:45 PM
cheezit's Avatar
once again evac the ac you will need to seperate the line to remove it not reall a big deal just a disconnect tool cost about 10 for the tools.
Old 06-22-2011, 10:57 PM
mustang9701 mustang9701 is offline
mustang9701 is gaining momentum as a positive member of FTE.
we just did mine here last week. pulled motor and put studs in also. much easier with the motor on the floor doing the heads with the studs. trying to torque those studs to spec with motor in the truck would be a task. 3 evenings and one saturday job was complete
Old 09-27-2011, 09:54 AM
sdgrossman1994 sdgrossman1994 is offline
sdgrossman1994 is starting off with a positive reputation.
Remove the Cab or not.
To All,
Many have posted take the cab off, leave it on, the face is, if you want to just remove the heads and replace the head gaskets you don't have to remove the cab. If you plan on upgrading the head bolts to head studs, then you have to remove the cab. You cannot install the head studs and install the heads with the cab on. The job of taking the cab off is not hard. I took my truck to Twisted Diesel in Chesapeake, VA and they had my cab off in 1.5 hours. Heads off and to the machine shop in a few hours. The longest part of the job was waiting for the inspection from the machine shop. Both heads were cracked, and had to be replaced. The total job took one week and I was back on the road and good to go. I now have almost 20 miles on my truck since the repair and I have not used a drop of oil or coolant since.
Old 09-27-2011, 11:30 AM
Quote:
Originally Posted by sdgrossman1994 View Post
To All,
That is a BIG lie. If they told you that...Sorry they lied.
I did mine with cab on installed ARP head studs, truck went in my garage on a Saturday, rolled out on the next Saturday. Thats with having the heads checked.
Flat Rate for Cab Removal and Head Gaskets? MBDiagMan 6.0L Power Stroke Diesel 5 12-13-2015 02:52 AM
Thinking of coming to the "dark side" so just poking my head in the door! Shovelheadrob 6.0L Power Stroke Diesel 12 12-08-2015 08:14 AM
2005 AXLE CODES mxpro 1999 to 2016 Super Duty 9 01-13-2014 04:53 PM
do 6.0 diesels have head gasket problems? jcweis1 6.0L Power Stroke Diesel 59 05-02-2013 02:24 PM
I have a 1990 F350 crew cab with blown head gaskets jimm38 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-21-2011 08:06 PM
Tags
2005, 350, cab, duty, f250, f350, ford, gasket, gaskets, head, instructions, problems, removal, super, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
