BUILD THREAD: Bringing a '76 back from the dead (Pic. Heavy 56K BEWARE)
  #46
Old 10-22-2011, 07:47 AM
moparmusclecars's Avatar
moparmusclecars
moparmusclecars is offline
nice truck! keep up the good work!
  #47
Old 12-22-2011, 01:13 PM
kelsey_kaye's Avatar
kelsey_kaye
kelsey_kaye is offline
No posts in two months...
BUUTTTTT.. finals are done and christmas break has begun soo we have a couple updates.
I was finally able to get the engine on a stand:
It wasn't too pretty looking on the inside:
Right before it got dark I was able to remove both the doors.. and no more toolbox:
So far it's been small victories, but the project is still pushing along. I'm still stripping down the engine so it can be shipped off to be built. Next up is removing the bed and removing more rivets on the chassis.
  #48
Old 12-22-2011, 01:26 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Originally Posted by kelsey_kaye
So far it's been small victories.
Those small victories are what eventually wins the war, keep up the good work.
  #49
Old 12-22-2011, 01:36 PM
BDawg171's Avatar
BDawg171
BDawg171 is offline
Nice! Hit it hard while you're home on break. Keep us updated.
  #50
Old 12-29-2011, 11:15 AM
kelsey_kaye
My dad has been so kind as to make sure I'm limited on time to get some work done. I had to help him at the shop since his only employee (my oldest brother) is on vacation. With only a small amount of time before darkness sets in, I'm not where I'd like to be, but it's still moving.
Windshield is out and the cab has been fully stripped besides seat belts and back glass. I need to go buy the right torx nut to remove those.
I found a little of my grandpa's creativity.
Whatever works right?
I'm still working on the bed removal. Almost 40 years of rust really takes a toll on those bolts. I had to drop the side gas tank because my cheater bar was just a bit too long. I also started grinding on the two bolts that don't have nuts attached at the bottom, and I got around to removing the tailgate and almost all the trim on the body.
Until the next update... Have a Happy New Year everyone!
  #51
Old 12-29-2011, 01:12 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Let those seat belt bolts soak a while. Mine broke 2 torx bits trying to get them out. Not fun.
  #52
Old 12-29-2011, 04:52 PM
77393's Avatar
77393
77393 is offline
+1 on soaking the seatbelts, I broke one bit myself. Keep on stripping her down.
  #53
Old 12-29-2011, 05:05 PM
plumber01's Avatar
plumber01
plumber01 is offline
I love your grandpas handy work, my grandpa cut heater hose and did the same thing with my truck, Glad to see this coming along.
  #54
Old 02-07-2012, 09:39 PM
kevin316's Avatar
kevin316
kevin316 is offline
Going through some old posts and found this. Any updates?
  #55
Old 02-08-2012, 12:24 AM
kelsey_kaye
Hmmm.. seems I forgot to post. I've been busy since school has started back up. I ended up actually removing the bed all by my lonesome with only some 2x4s and a creeper. That means no excuses for all you guys out there. Nah... jk. I got around to removing only a couple of the rivets off the back end, and I'm debating whether I want to proceed with doing that or not. I'm not all that comfortable using 3/8" bolts even if they're grade 8. Do others drill the holes out to 1/2" or am I just over thinking this?
This is how I left it:
  #56
Old 02-08-2012, 06:29 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
I'd say for crossmembers 3/8" is ok. For spring hangers, I would go with 1/2". ....but that's just me. If you don't need to remove rivets, why bother? The bolt eventually has a chance to loosen up. The rivet won't. If you DO cut the rivets out, use red loctite putting it back together.
Keep up the good work. Slow and steady wins the race.
  #57
Old 02-08-2012, 08:21 AM
Tees77f150's Avatar
Tees77f150
Tees77f150 is offline
Just an FYI, when I was tearing my dent apart, I found using a 50/50 mix of tramnsmission fluid and acetone worked wonders on rusted bolts. I put the mix in a glass cleaner spray bottel, and labeled it.
Keep up the good work, the progress never goes as fast as we like. It's also nice that you were able to get your Pap's truck, gives it that much more meaning. Don't forget to keep us posted we like seeing another dent getting fixed up, and you know how well we like the pictures!!!
  #58
Old 02-08-2012, 10:40 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Nice progress so far. I can totally understand the feeling of working on your grandpa's truck, as I am currently reviving a 74 F100 that dad bought new. Ironically, it looks very similar to your truck, right down to colors. Different shade of green being the only real difference. It got parked in 2007, but for a much different reason.
Link to my build thread: https://www.ford-trucks.com/forums/1...ner-truck.html
Don't want to confuse anyone by inserting a photo of such a similar looking truck, if you know what I mean....
Once you have it back on the road, just driving it will always bring back memories of time gone by. Keep up the great work!
  #59
Old 02-08-2012, 12:42 PM
USArmyTaterness's Avatar
USArmyTaterness
USArmyTaterness is offline
Good to see this revived keep up the work.
  #60
Old 02-08-2012, 08:09 PM
E.R.W.'s Avatar
E.R.W.
E.R.W. is offline
truck looks good, I wish the body on mine was that nice. Why are you removing the rivets?
Quick Reply: BUILD THREAD: Bringing a '76 back from the dead (Pic. Heavy 56K BEWARE)
