1st inpressions Stage III injectors
Can someone shed some light on the difference between 238cc injectors and 250cc/100%? I understand they both use the 7.1mm plunger and barrel instead of the 6.0mm. Is the difference in the intensifier piston?
Full Force 238 or 250cc for $1850
Rosewood 238cc for $1650
My goal is about 450+hp.
By the chart:
200cc/100 good for 430-460
238cc/100 good for 475-550
250cc/100 good for 480-550
By the chart:
By the chart:
By the chart:
The nozzle size dictates how fast the injectors can "empty" so to speak. The larger the injector, the larger the nozzle needs to be to allow the full amount of fuel to be pushed into the cylinders. With my 238/100s, they provide PLENTY of fuel, and I'm quite sure would get me over 500 if I have the air (and block) for it. What power levels are you looking to attain? 250s will get you up in the mid to upper 500s I'm sure, if you have a block built to handle it.
I was looking to be around 500 or more but I realize how much it would cost to get me there, funds I dont have now. I realize the price difference for 450HP and 550HP is massive so that will be the deciding factor. I have a list of all the things I need to get to those power levels, its long and pricey. You said PMR block are you refering to the block itself or a gridle, rods and so forth that could be done to strenghten it? I dont want power levels so high that Ill have to fill the block and not be able to drive it whenever I want. I have plenty of time to wait and figure out the "REAL" power levels Id be happy with
One of my biggest problems right now is I dont have AE yet and I still have the 3:73 gears and 38s. My thinking was... Ill see how it goes.... yeah.... she dont go no where fast lol. I dont know what that equates to as a final gear but it cant be good, 4:30 gears went from mid range of the list to the top.
238's:
"Stage three reman performance injectors to increase the performance and horsepower of your powerstroke diesel. The injectors in the 94-97 Ford Powerstroke will increase horsepower up to 5oohp at rear wheels with a custom performance chip. In the 99-03 Powerstoke diesel you will have to run a custom programmed chip to make the transition from split shot injection to the new single shot injection. Horsepower increases up to 500hp and mileage increase from the more effecient single shot design. These injectors have new nozzles and tungston coated plungers and barrels. The larger 100% or 200% over size nozzles allow for better control of fuel delivery during the combustion cycle with allows for the added horsepower over the stage one injectors. The larger hybrid plunger and barrel in these injectors move more fuel for the same stroke as the stage two injector. These hybrid injectors are designed to operate with stock High Pressure oil. This is optimal for the 17 degree HPOP. This saves money on a new HPOP system by utilizing the system you already have. Built and flowed to within 1%. Please contact us for a list of approved custom chip tuners in your area. Come with an outstanding 18 month warranty. Complete set of eight. Core charge required.
250's:
"Stage three reman performance injectors to increase the performance and horsepower of your powerstroke diesel. The injectors in the 94-97 Ford Powerstroke will increase horsepower up to 525hp at rear wheels with a custom performance chip. In the 99-03 Powerstoke diesel you will have to run a custom programmed chip to make the transition from split shot injection to the new single shot injection. Horsepower increases up to 525hp and mileage increase from the more effecient single shot design. These injectors have new nozzles and tungston coated plungers and barrels. The larger 100% or 200% over size nozzles allow for better control of fuel delivery during the combustion cycle with allows for the added horsepower over the stage one injectors. The larger hybrid plunger and barrel in these injectors move more fuel for the same stroke as the stage two injector. These hybrid injectors are designed to operate with stock High Pressure oil. This is stretching the limits for the 17 degree HPOP. This saves money on a new HPOP system by utilizing the system you already have. Built and flowed to within 1%. Please contact us for a list of approved custom chip tuners in your area. Come with an outstanding 18 month warranty. Complete set of eight. Core charge required.
I still haven't found the difference between the two. I think the 238's are in my future, they will put me right where I wanna be.
Do you know if DP has a preference between FF or Rosewood for tuning. Both seem to have a good reputation...
Joe, of all the brands available why did you chose FF/Casserly?
#29
I believe DP sells the FF/Casserly injectors on their web site, so if you plan to go with DP tuning, I would probably suggest the FF/Casserly injectors, though I am sure Jody (and the other tuners as well) could make a tune that would work fine with either.
#30
