Transmission No Shift into High - Ford Truck Enthusiasts Forums
Old 06-20-2011, 10:15 PM
dbradicich dbradicich is offline
dbradicich is starting off with a positive reputation.
The problem with the transmission is as follows.
ffice:office" /><O:p></O:p>
All was good, until I noticed,, (while pulling a 1965 M35 Massey the Tractor weighs 6,017 lbs with all the ballast… probably less than 7000 total with trailer and all the crap)
<O:p></O:p>
Without notice,, would not shift into high gear (4<SUP>th ????</SUP>)
<O:p></O:p>
Symptoms are as follows.
Will not shift into high (4<SUP>th</SUP>?)
OD Light flashing on lever
(Stopped truck – Shut ‘er down)
<O:p></O:p>
Restart –
No OD light flashing
Still will not shift into 4<SUP>th</SUP>
<O:p></O:p>
(stopped truck - shut her down again)
Read a bunch of crap on internet and changed Rear Wheel Speed sensor in the pumpkin… I figured why not the $ 17.99 part,, as opposed to the $ 3,500 rebuild.
Pulled battery NEG cables, all lights on 10 min to draw down power on computer dealyawhatchit (saw that on the diesel forum thingy too.)
Reconnect..
Restart
Still no 4<SUP>th</SUP>
No OD Light flashing
When OD button pushed(OD light on) truck responds to quasi engine braking
(rpm’s stay constant according to speed)
Button pushed again (OD Light OFF)
Truck shifts normally up through gears, with the occasional HARD SHIFT between 2-3. (and I mean HARD!)
At about 50 mph or any other speed for that matter, when you pull foot off the pedal she immediately drops RPM to appx 700 (lower than idle I think)
<O:p></O:p>
Other notes.
<O:p></O:p>
Truck has sat all winter long unregistered,, and for quite a while before that. Total miles 141000. Tranny fluid and filter changed once last year.
Normal use for truck,,, probably never towed more than 10,000 once in its lifetime. But is used for getting hay, horses, and other farm crap.
About 1 month ago the “check engine” went to flashing.. but upon restart it went away and has not come back.
Doesn’t have any mods.
Needs Cam Switch Recall done.. I just need to take her down to dealer,, (here in KY they charge for that BTW… doesn’t seem right to me,, but they told me it was appx 200-280 depending on if they changed oil or not??????)
>>>>>>One more thing – REVERSE is like you have a high gear… ENGINE LUGS Down hard, and sometimes stalls..
<O:p></O:p>
To me it seems more electrical than mechanical, except for the fact that maybe its sat too long and gummed up something in the valve body and needs a flush.
I also pulled all plastics around steering column,, no chaffing or worn crap associated with harness or area around OD wire entrance to lever.
I have read horror stories and I mean (HORROR) about this so called “mechanical diode?” What the heck is that??? How can something be mechanical and a ‘diode’ at the same time?
Anyway,, my reading and research says,, this is either some solenoid, OR 40 or 50 other computer problems, or a complete rebuild.
<O:p></O:p>
Anyone who has been down this path, the help is appreciated…. Ford wants 150 bucks to read the codes thrown by the tranny. AAMCO will do it for free, and that scares me in either case.
Old 06-21-2011, 04:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Mechanical Diode is a trade name for a one way clutch. It transmits torque in one direction, but not the other direction, just like a diode does for electricity. It was used in the diesel transmissions for the first 3/4 of the 2001 model year.
You're right, the problem is at least one of 50 or so possibilities. You need to get the codes read to find out where to start. If you don't have the codes, and rebuild the trans, you stand a good chance of having the same problem with the new trans.
Old 06-21-2011, 11:01 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
There are folks that are part of our community here that have code readers that are compatible with the Ford diesel trucks that might be happy to do that for you.
It would be easier, however, if they knew where you were located.
Pop
Old 06-21-2011, 01:18 PM
Lexington Kentucky -
Old 06-21-2011, 03:22 PM
OK, then.
Anybody near Lexington able to pull codes???
Pop
Old 06-21-2011, 06:55 PM
ok... now.. did a little more checking on this... went under the hood and found a blown fuse a 30Amp MAXI... pretty sure this is the culprit. several of my trips to the internet have linked this fuse with the pumpkin reference (now a new one) and the OD Switch shifting lever wiring chaff issue.. Now I did look at the chaffing and couldnt really see any.. I was clearly looking for obivious issues around where the tiny wired comes out of the lever and any other "obvious" items.. further expanding on my findings its about 1 hour to the closest shop with a code reader,, (I put lexington,, but I live in the sticks actually)
with this new info.. Blown Maxi fuse and the like,, suggestions are welcomed.... I WILL ALWAYS try all the simple stuff before I go downtown and spend the big bucks...
Old 06-21-2011, 07:03 PM
in other words.... Please list possible causes for 30A Maxi to blow!
Old 06-21-2011, 07:16 PM
Please don't assume that we can somehow know what year, model, trim level, truck you have, nor what specific fuse you found blown.
We can only help you when you give us something to go on.
We want to help, but we have to know what, specifically, we're working on here. Ford made wiring changes over the years, changed the locations of fuse boxes, etc., so yours probably isn't "just like" mine.
Pop
Old 06-21-2011, 09:14 PM
o,, I thought the profile stuff would show up.
1FTNX21FX1EA60159
DATE 09/00
I am calling this an '01 F-250 SD 4 x 4 super Cab (door and a half)
No Modifications.. XL with Bench seat,, no fancy stuff.
Fuse #17
Old 06-21-2011, 09:16 PM
So.. I changed the fuse.. It did not blow again.. 'good news' however operation of vehicle did not change.. still no shift into high.
It did a MAJOR Hard Shift into reverse though and stalled! OD light did come on and I did not put it on.. didnt do it again though.
same problem
Old 06-21-2011, 09:32 PM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
I'm not sure there's good news on your horizon... Tell us about the trany fluid. What does it look like (pink, red, orange, brown) Does it smell "burnt"? Is there any shiny flakes visible (you can wipe some on a clean white paper towel and look)
Also, when it shifted hard into reverse, I'm assuming you had just shifted out of park to reverse, was there any delay in the reverse engagement? Was it the normal amount of time, just hard?
Old 06-22-2011, 09:08 PM
So,, I went out to check the fluid... there wasnt any on the stick.. drove it around a bit, warmed everything up.. found a piece of level ground (hard to do here) still nothing.. I guess i put in about 2 quarts.. little less probably. drove it around again..
All hard shifting has gone away.. hard reverse no more.. anyway when it did that before it was the 'normal' amount of delay..
Basically same deal.. OD does work normal now.. BUT,, no 4th gear. I can go around with all kinds of power in 3 gears..
I apologize I can not tell you what the fluid smells like, I can not smell.. It is brownish but not gross like other transmissions I that were known bad... There are no filings or silver crap in it.. once I finally got some on the stick and drove around..
Old 06-22-2011, 09:57 PM
Quote:
Overdrive IS 4th gear.
Old 06-23-2011, 03:01 PM
hhowell1990's Avatar
hhowell1990 hhowell1990 is offline
hhowell1990 is starting off with a positive reputation.
I'm currently in louisville, and have my OBDII scanner with me, it's not an AE, but can pull some ford specific codes that the scanners at auto parts stores can't pull. if it's not too far of a drive for you I'd be able to pull the codes for you and probably get some insight into the problem, if you're able to come up here before sunday morn. just PM me
Old 06-23-2011, 05:21 PM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
I would get the codes read first and foremost. That WILL tell you something. After that I would drain the pan and look at the fluid and look for shavings in the pan. I had some very similar things happen to mine 3 weeks ago and I just installed my new transmission last night. Brown fluid is not a good thing in your transmission. My fluid had 20k miles on it and was toast. Reading the codes and a fluid drain/pan drop will tell you a lot IMO.
79 Ford truck instrument harness wiring guide John Rowe 1973 - 1979 F-100 & Larger F-Series Trucks 15 11-21-2016 10:13 AM
High EOT's AFTER repairs. 06FUN 6.0L Power Stroke Diesel 115 10-29-2016 08:53 AM
SERIOUS light issues old blue beast 1987 - 1996 F150 & Larger F-Series Trucks 3 08-05-2016 09:28 PM
Rough Idle AFTER Warm-Up - P1211 (Injector O-Rings?) rockhound_jb 1999 - 2003 7.3L Power Stroke Diesel 8 03-03-2016 06:16 PM
CAB OFF Suggested Maintenance TRILLS 6.4L Power Stroke Diesel 5 09-10-2015 09:15 PM
Tags
04, 2003, 350, diesal, excursion, expedition, f150, ford, gear, gears, hard, high, park, reverse, shift, shifts, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
