Transmission No Shift into High - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 04-29-2014, 08:06 AM
dbradicich dbradicich is offline
dbradicich is starting off with a positive reputation.
The answer
Warped pump... Transmission rebuild... Took the transmission guys two rebuilds to get it right. They tried to be cheap and not replace the pump.
  #32
Old 04-29-2014, 08:08 AM
The answer...
Warped pump,... Transmission rebuild. Took the transmission guys twice to get it right trying to be cheap without replacing the pump.
  #33
Old 04-29-2014, 08:21 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
That P0728 is an intermittent speed sensor, and the P0768 is a bad shift solenoid. My PC/ED didn't have the codes, but my AE did.
Great job on reporting back!
1994 F350 Just got it with problems triggernut7788 1987 - 1996 F150 & Larger F-Series Trucks 36 10-12-2011 09:39 AM
Intermittent Battery Light lakerats 1999 to 2016 Super Duty 4 03-17-2011 03:40 PM
Intermittent Battery Light lakerats Electrical Systems/Wiring 5 12-08-2010 09:00 AM
Intermittent Battery Light lakerats 1999 - 2003 7.3L Power Stroke Diesel 18 10-16-2010 10:10 PM
1996 F250 E40D - No Gears Rooster368 Clutch, Transmission, Differential, Axle & Transfer Case 3 12-06-2009 08:47 PM
Tags
04, 2003, 350, diesal, excursion, expedition, f150, ford, gear, gears, hard, high, park, reverse, shift, shifts, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
