Transmission No Shift into High - Page 2 - Ford Truck Enthusiasts Forums
Old 06-23-2011, 04:44 PM
dbradicich dbradicich is offline
dbradicich is starting off with a positive reputation.
Mark - Thank you - I specifically meant the Button,, my bad.
HHowell - Too far to drive with a risky Transmission - 3 hours total.
Everyone!!! OK OK,, I submit - I will go get codes read....
I just feel like this is some gummed up valve body,, I mean,, after all,, I actually have blown transmissions before.. MANY in fact.. Never had one this freakin Stealthy when it blew though...... Reading Codes tells me that this is going to be bad, and it appears no one has ever had good luck with one of these transmissions when it goes Feminine on ya.
Just in Case.... Where is the Best Place to buy a Recon Transmission.. I will do it myself,, Send me your best Websites.... I AM NOT giving some shop 3000 dollars for a 1/2 day Job...
Please also tell me how to get away from the Mechanical Diode, just in case I have that.. I dont ever want that thing creeping around my truck again!
Old 06-23-2011, 04:51 PM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
Quote:
I went with a BTS. It's going to be more than 3k though. Give Brian a call and you will see why people like him. I guarantee he will help you try to fix it over the phone before he lets you buy anything from him.
Brians Truck Shop
Old 07-04-2011, 04:08 PM
Well.... wouldnt you know it... There are no codes.. Now what?
Old 07-04-2011, 04:40 PM
shacks87's Avatar
shacks87 shacks87 is offline
shacks87 is gaining momentum as a positive member of FTE.shacks87 is gaining momentum as a positive member of FTE.
Did you drain the fluid and drop the pan as suggested?
When mine did this the OD was shot and had to rebuild it.
Old 07-04-2011, 07:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I think the next step is to read the codes with a reader that can read Ford transmission codes. When the OD light flashes a code is stored in the PCM. It stays in the PCM for about a month after the last time the light flashed, unless someone disconnects the PCM or the batteries.
Old 07-04-2011, 08:06 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
I had a problem with mine not shifting out of second gear and it wound up being one on the little (I don't know what to call it) pins that transfers the fluid to shift gears. It developed a burr on it and got stuck. I was already committed to a BTS trans so I had him build mine. Great piece of mind knowing I'll never have to worry about the tranny again. Mine didn't through any codes either.
Old 07-04-2011, 11:05 PM
Mark, read my original post... 'i' disconnected batteries in an attempt to reset computer
Old 07-05-2011, 05:42 AM
I see a few ways to approach this since you erased the codes that would have told us where to start.
Drive it until the OD light flashes again meaning the codes are back. Or you could rebuild the trans, that will probably, but not certainly fix it. Or you could pull the valve body and see if there are any stuck valves.
Old 08-12-2011, 02:58 PM
Code 728 or 768 3/4 shift solenoid.... Now what????
Old 08-12-2011, 04:48 PM
Been awhile but maybe I can just swap this? Where is it?
Old 08-13-2011, 09:58 AM
I guess this post is dead
Old 08-13-2011, 10:25 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
You let it go dead by waiting a week between posts so there was no feedback to the posters who were trying to help you. I would follow the suggestion that Mark made in post #23, I'd drive it until the tranny threw a code and then be prepared to scan it with a scanner that can read the codes (then post the results to a NEW THREAD titled: "Pulled Codes #xxxx, any ideas?") OR I'd pull the valve body and see if I could find a problem. In the new thread you could recap the symptoms and what has occurred to date.
  #28
Old 08-13-2011, 10:49 AM
izzybird's Avatar
izzybird izzybird is offline
izzybird has a very good reputation on FTE.izzybird has a very good reputation on FTE.izzybird has a very good reputation on FTE.
So are you saying you retrieved P0728 and P0768? I don't even see those numbers in the Trouble Code Charts.
  #29
Old 08-21-2011, 08:38 PM
I don't know what else I can do for you.
  #30
Old 05-05-2012, 10:57 AM
Well,, this is still a problem - Today I changed the Fluid, Filter and Solenoid Pack.. The fluid was fairly clear,, a little brown, not excessive,, I cant smell really but i dont think it was "burnt" the magnetic chip detector had a pretty good amount of black junk on it, but I wouldnt call it excessinve,, all black stuff, maybe about 1/16" thick or so? no other noticeable issues, no shiny stuff or sludge anywhere else in the pan.. .... So,, anyone have any more ideas?
Rough Idle AFTER Warm-Up - P1211 (Injector O-Rings?) rockhound_jb 1999 - 2003 7.3L Power Stroke Diesel 8 03-03-2016 05:16 PM
1994 F350 Just got it with problems triggernut7788 1987 - 1996 F150 & Larger F-Series Trucks 36 10-12-2011 08:39 AM
1949 F3 Parts Advice Needed 49truck 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-09-2011 05:43 PM
Intermittent Battery Light lakerats Electrical Systems/Wiring 5 12-08-2010 08:00 AM
Intermittent Battery Light lakerats 1999 - 2003 7.3L Power Stroke Diesel 18 10-16-2010 09:10 PM
Tags
04, 2003, 350, diesal, excursion, expedition, f150, ford, gear, gears, hard, high, park, reverse, shift, shifts, transmission, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
