fuel economy
mpg
I have the exact truck, mine is an 02. I have had a mpg drop lately that im trying to figure out why? But i normally get about 18-18.5 with a mix of highway and a bit of around town driving. I get about 15 with only around town driving. I can squeak out 20-20.5 in perfect conditions, empty truck on very long freeway trip at 65mph. And yes when all is perfect i can get over 700 miles on a tank. Joe
Will anyone that has a 7.3 manual, extended cab, longbed, 4x4 tell me what mpg they get?
Joe the mpg in the 2000 crew cab gets 18 mpg pulling a trailer out to Colorado. Joe have you been adding lucus to your fuel? if you have been adding lucus to your fuel you may want to stop, because I have been told it gums up your injectors causing lower mpg. I just stopped on the 700 miles tank. On that tank it was city and highway. I went to Tenn picked up a forewheeler, and drove back to NC.
mpg
No i have never used lucas before.
Now again i have an 02 f250 7.3 4x4 6 speed long bed.
My mpg normally is 18-18.5 with a mix of highway and around town.
My mpg is about 15 around town.
My mpg is 20-20.5 on a long freeway trip with empty truck at 65mph.
Lately mine has dropped. Working on correcting some things like leaky intercooler boots,fuel filter change,different fuel etc to see if it goes back to normal. I have not driven enought lately to tell. Thanks Joe
with clean air filter, clean oil, additive (diesel kleen or similar) ex cab long bed 4x4 6-speed the best I have ever gotten with DP on 80 economy is 19-20 all freeway. I get considerably less around town lately, and not quite sure why. I do have 305/70/16's on it though so a little bit more meat than the stock size tires. Ive found that the best way for getting mileage with my particular truck is to keep the RPM's under 2000, but also to pay attention to EGT's and Boost. It does you no good to be under 2000 RPM but have to put the pedal down and be dumping fuel creating high EGT's trying to pull up a hill. Use the 6-speed and shift and use neutral as much as possible
EXTREMEFUN1300
12-21-2013 05:11 AM
joekrned
New Member Introductions
10-13-2008 08:39 PM
Jeremy2792
1999 to 2016 Super Duty
18
06-15-2008 02:37 PM
