cruise won't work 02 F350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-20-2011, 05:24 PM
74redone 74redone is offline
74redone is starting off with a positive reputation.
I bought an 2002 F350 and the cruise doesn't work. Looking for a starting point.
T%hanks for the help!
Matt
Old 06-20-2011, 05:29 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Does the cruise control light illuminate when you push 'ON', then 'SET ACCEL'?
Old 06-20-2011, 06:09 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Jumper the SCDS and re-test.
Old 06-20-2011, 06:29 PM
Quote:
What is the SCDS? I looked for a fuse but I didnt see one for the cruise. Nothing works. No lights on the dash or other buttons that are part of the cruise.
Thanks for the help!
Matt
Old 07-19-2011, 09:22 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Sorry to bump this, but my 02 250 started doing this randomly too. At highway speeds, I was not able to set the cruise control even after toggling the switch on and then setting, multiple times. The little green speed control light flicked on and off in less than half a second.
Anyone got a clue what's up?
Old 07-19-2011, 09:31 PM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
Look at the sensor coming out of the anti lock brake module in the engine compartment. If it had the recall done then a fuse was added there to prevent these things from catching on fire. Check the fuse. If its an intermittent problem look at the butt connectors where that fuse was added, it might have corrosion at the connectors. I looked at the "quality" job my dealership did, drove it home and then replaced it all with watertight butt connectors and a water tight fuse holder. Just a suggestion.
Old 07-20-2011, 07:17 AM
Quote:
The recall added a fused harness to the SCDS on the master cylinder, not the ABS module. The harness is a factory-assembled unit and should not have an "butt-connectors" in it. See instructions for 05S25 with supplements.
Pinky,
Follow the instructions given in post #2. The switch can become intermittent or exhibit high resistance and the quickest way to verify or exclude it is to bypass it temporarily. A straightened paper clip or similar works fine, just ensure it cannot short to ground during resting.
Old 07-20-2011, 06:09 PM
okay I checked my fuse and it is destoryed by brake fluid that leaked on it. What size fuse should this have? Would this fuse being out also affect my brakes?
matt
Pinky,
Old 07-20-2011, 07:33 PM
Go to a dealer's parts window and purchase a recall kit that includes both the harness and the switch and replace both of them. About $20 or so for the parts.
Old 07-20-2011, 08:38 PM
My truck was not included in the recall. What is the SCDS?
Old 07-21-2011, 07:04 AM
That's the switch on the master cylinder that leaks. Speed Control Disconnect Switch.
Are you sure you weren't included in Recall 05S28? My 01 F250 certainly was. You can check for open recalls on your vehicle at Recall Notices| Ford, Lincoln & Mercury Owners | FLMowner.com
Old 07-23-2011, 10:36 PM
clean everything up and put in a new fuse and cruise works like a champ!!! Thanks ProjectSHO89!!!! I will be cruising to SD this Oct.& Dec.!!
Matt
85 F350 Cruise issue 62FE4x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-11-2016 09:11 PM
Cruise Control Issue 62FE4x4 1987 - 1996 F150 & Larger F-Series Trucks 8 04-30-2016 11:30 PM
2004 F350 V10 Cruise Question TKulak 1999 to 2016 Super Duty 3 01-17-2016 10:28 AM
Cruise and horn don't work nebechanezer 1987 - 1996 F150 & Larger F-Series Trucks 6 04-26-2011 01:15 PM
Dead Cruise control dyoungen 1987 - 1996 F150 & Larger F-Series Trucks 1 12-01-2010 04:34 PM
Tags
1999, 2000, 2002, 2004, 350, 99, control, cruise, doesnt, econoline, f350, ford, wonr, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
