I hear a noise coming from the rearend of my 2003 Explorer, 105K. How hard is it to replace the bearings? Is it hard to rebuild these rearends or should I take it in? Thanks
if it is a wheel bearing, they are disassembled and reassembled with a new bearing onto the hub with a 12 ton press. YOu can take the unit off the truck and take it to a shop to have it assembled, then you can reinstall onto the truck. If your talking about the differential unit, thats another story...... im assuming you have independant rear suspension ?
