3 Wires on My New HEI Distributor, Am I Wiring This Right?
Proform Parts 66964 - Proform Ford HEI Distributors - Overview - SummitRacing.com
The link above is for the distributor I just purchased. My truck is a 1967 model F100 with the old points setup. I'm in the process of installing a 351W and I am trying to convert this over to HEI..... but there is no diagram whatsoever that came with the distributor. One wire is blue, another black and the other is red. I am thinking that:
Red goes to the the positive side of the coil as well as the 12v feed such as the ignition switch?
Black is a ground?
Blue goes to the negative side of the coil as well as the tach feed.
Does this seem correct? Please correct me if I'm wrong. Thanks!
Black is a ground?
Here is some wiring info.
Take the cap of the new dist and see what is inside it under the rotor.
Just a magnetic pickup?
The harness you will need is a junk yard item.
https://www.ford-trucks.com/forums/5...ml#post4418992
Jim
Jim
This is what a one wire HEI Distributor looks like.
FORD 351w Windsor Sbf HEI DISTRIBUTOR COIL Blue New | eBay
Mitchapalooza
06-08-2016 12:48 PM
Jklnhyd
02-26-2014 01:16 PM
dirtynorth49
57
01-20-2012 03:11 AM
rockcrawler_101
12-22-2011 10:42 AM
150, 1978, 1986, 350, 351, 360, connection, distributer, distributor, electrical, ford, hei, windsor, wire, wires, wiring
