Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 06-19-2011, 06:50 PM
MUSKRATT2 MUSKRATT2 is offline
1985 Ford F-350
MUSKRATT2 is starting off with a positive reputation.
92-96 Tailgate interchange?
I have an 85 F350. I want to put a 92-96 tailgate on the back because I'm going to put a roll pan on it & I want the clean look. I have the hole tailgate with all the hardware.
I have read threw the tips section about tailgate interchanging but it doesn't clearly define what needs to be done to add a 92-96 gate on the truck.
My question is this, what all needs to be done to the bedsides to add a 92-96 tailgate to my 85? Do I need the hardware or what? At one place it says smething about drilling but it doens't say what.
__________________
  • 1964 Ford Thunderbolt Clone
  #2 (permalink)
Old 06-20-2011, 01:31 AM
drumfield's Avatar
drumfield drumfield is offline
Garage is empty, add now
drumfield has a good reputation on FTE.drumfield has a good reputation on FTE.drumfield has a good reputation on FTE.
Not sure, but I think it's a direct swap.
From what I remember, drilling is only required if you put a newer "cable" gate on an older "strap" type truck.
__________________
Doug
Texas Chapter Member
'85 F250 4X4 XLT Lariat Explorer, 460/ZF5/BW1345/D44HD-3.54/D70-3.54LS
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein
  #3 (permalink)
Old 06-20-2011, 04:43 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is online now
1992 Ford F-150
SideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant futureSideWinder4.9l has a brilliant future
Height/Width, yeah, they're a direct swap...
Latches, on the other hand are totally different....The 80-86's have a square piece the latch presses against....
The 92-96 style uses a pin in the bed, and a setup very similar to a door....Complete different setup....
__________________
Wesley
1992 F-150 Michelle-300I6 w/ 5 Speed
Hurst Short Throw Shifter/ Cold Air Intake
Owner of Renegade Auto & Heavy Truck Solutions, LLC
19.31 E/T @ 68.78mph
  #4 (permalink)
Old 06-20-2011, 04:56 AM
1985 Ford F-350
What has to be done to make the switch? Any drilling ?
__________________
  #5 (permalink)
Old 06-20-2011, 08:24 AM
1992 Ford F-150
Try cutting and welding on the bed and tailgate to swap the latches...
__________________
Wesley
  #6 (permalink)
Old 06-22-2011, 01:39 PM
1985 Ford F-350
Is a 90 model bed going to be the same? I have a friend that has one & I can get the stuff off of it I need.
__________________
  #7 (permalink)
Old 06-22-2011, 06:46 PM
Eddiec1564 Eddiec1564 is online now
Eddiec1564 is gaining momentum as a positive member of FTE.Eddiec1564 is gaining momentum as a positive member of FTE.
The hinges are diffrent too. Got to cut spot welds that hold the hinges to the bed and reweld them back on.
A PITA in my eyes and Yep, I got a 89 tailgate for my 84 and found out the hard way many years ago....
If all possable use the 90 bed, it will directly bolt on the older truck. Only thing diffrent will be the wheel arches and most people would not even notice it.
__________________
95 E350 460/E4od 4.10 The Bus
89 F250 2x4 302/AOD 3.55
84 F250 4x4 300/np435 3.55 The BLUE MULE
85 Plymouth Caravelle
73 Buick LeSabre
  #8 (permalink)
Old 06-22-2011, 08:11 PM
newrider3's Avatar
newrider3 newrider3 is offline
1982 Ford F-100
newrider3 is gaining momentum as a positive member of FTE.
Umm, seems like a whole lot of misinformation going on in this thread.
No, it is not a direct swap. You need every piece of hardware from the donor truck, including the hinge trunnions, rubber bump stops, latch pins, etc.
The hinges are simply bolted on. The newer ones use a captive nut assy inside the bed, but you can use washers and bolts on yours. You have to fiddle with the hinges until they are both lined up well.
You then have to drill holes for the bumpstops, and for the latch pins. The surface where you will be bolting the pins is angled, so you have to find some spacer stock the right diameter, and cut it on an angle to allow you to mount the pins straight.
It's more work measuring and marking everything carefully than actual labor. A couple hours to an afternoon depending on your skill level. Well worth it for a tailgate that is still straight and opens and closes well.
Click the image to open in full size.
__________________
1982 F-100 Shortbed 2wd - 300/6: Clifford Intake, 500cfm Edelbrock AVS, EFI manifolds, true duals, COMP 260H, port and polish, - M5R2 trans - 3.25 9"
1997 F-350 Crew Cab Longbed 4x4 - 7.3 PSD 5spd - beat to crap work truck resurrection
  #9 (permalink)
Old 06-22-2011, 09:14 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
It's not too difficult to do. You will need all the hardware from the donor truck. When bolting on the pivot brackets, you can use one of the original bolts but will need a nut/bolt combo for the other hole as the pivot brackets are different lengths.
Here you can see the different latching setups. I held the tailgate where I thought it should sit(after pivots are mounted) and marked where I thought the latch pin would go. I made the hole a little larger so I would have some room for adjustment. The angle isn't too bad that you cant just bend it a little when it's mounted. I never had any problems latching the tailgate on mine.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
  #10 (permalink)
Old 06-23-2011, 10:06 AM
1985 Ford F-350
Thanks Guys, this is a big help!
__________________
  #11 (permalink)
Old 06-23-2011, 06:45 PM
1985 Ford F-350
I went down & looked at my buddies 90 model. After reading what you guy's have said & looking at where the striker is placed, it looks like all Ford did was just put a piece of sheetmetal there over what our trucks had in the early 80's. Nothing really fancy.
__________________
Tags
1992, 1993, 1997, 92, 9296, f150, f250, f350, ford, gate, interchange, tail, tailgate, tailgates, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
